My car feels down on power and like the exhaust is restricted...
Old Dec 9, 2012 | 10:32 AM
k-ore's Avatar
k-ore Is a GOD !k-ore Is a GOD !k-ore Is a GOD !k-ore Is a GOD !k-ore Is a GOD !k-ore Is a GOD !k-ore Is a GOD !k-ore Is a GOD !k-ore Is a GOD !k-ore Is a GOD !k-ore Is a GOD !
Question My car feels down on power and like the exhaust is restricted...
I noticed that my exhaust sounds muffled and i'm definitely down on power. Car boost perfectly fine to 1.2 bar. I'm running a catless exhaust and it basically sounds like something is blocking it when driving or even free revving. No CEL's or idiot lights are on in the dash. All my boost hoses are connected and tight. Plugs have less then 1000 miles on em.
I'm dumbfounded on what it could be, any suggestions?
Old Dec 9, 2012 | 10:45 AM
32krazy!'s Avatar
something in the turbo themselves? maybe open up the exhaust and have a look
Old Dec 9, 2012 | 12:28 PM
exhaust leak... ?
2001 996TT 3.6L and stock ECU
9.66
seconds @ 147.76 mph 1/4 mile
click to view
Old Dec 9, 2012 | 12:46 PM
johnspeed's Avatar
Originally Posted by MARKSKI@911tuning
exhaust leak... ?
Wouldnt you hear an exhaust leak and wouldnt be louder with a different tone?
Old Dec 9, 2012 | 06:04 PM
k-ore's Avatar
No exhaust leak, or else I would have mentioned that.
Old Dec 10, 2012 | 10:05 PM
Tim941NYC's Avatar
DV's?
Old Dec 11, 2012 | 06:23 AM
k-ore's Avatar
Originally Posted by Tim941NYC
DV's?
Blown dv's could cause the exhaust to feel and sound muffled/restricted and the power to be down?
Old Dec 11, 2012 | 07:58 AM
less power different exhaust tone. check the turbo wheels just incase on intake/exhaust sides... and check that they spin freely
#TeamAIM
Old Dec 11, 2012 | 08:50 AM
Tim941NYC's Avatar
What exhaust? baffle could have broken. But if a dv is opening enough the turbo needs to spin faster to make the 1.2 bar. so the wg would be closed forcing all the exhaust threw the turbo increasing back psi. Idle should sound the same.
Old Dec 11, 2012 | 11:08 AM
k-ore's Avatar
prodigymb: Sounds like we might be on to something then...
Tim: When I rev it, it sounds muffled, at idle it sounds fine. But I can tell the restriction is causing the exhaust sound to change and the engine to work harder to rev and build boost. I have custom mufflers, so do you think they still could break a baffle?
Old Dec 11, 2012 | 11:51 AM
johnspeed's Avatar
It does sound like a broken baffle would cause those symptons.
Old Dec 13, 2012 | 10:42 PM
TTurbRon's Avatar
TTurbRon is a jewel in the roughTTurbRon is a jewel in the roughTTurbRon is a jewel in the roughTTurbRon is a jewel in the rough
Val I'll give you a hand if you want. You got a lift to use?
Old Dec 13, 2012 | 10:43 PM
k-ore's Avatar
I appreciate that Ron, no lift that I have use of..I wish.
Old Dec 13, 2012 | 11:06 PM
Duane996tt's Avatar
Duane996tt has a reputation beyond reputeDuane996tt has a reputation beyond reputeDuane996tt has a reputation beyond reputeDuane996tt has a reputation beyond reputeDuane996tt has a reputation beyond reputeDuane996tt has a reputation beyond reputeDuane996tt has a reputation beyond reputeDuane996tt has a reputation beyond reputeDuane996tt has a reputation beyond reputeDuane996tt has a reputation beyond reputeDuane996tt has a reputation beyond repute
Clogged or collapsed cat?
Old Dec 13, 2012 | 11:17 PM
k-ore's Avatar
catless.
