Getting started on my 18G conversion, anything I'll need?
Old Dec 20, 2012 | 07:12 PM
Originally Posted by brnrdtns
Going to install my 18g turbos as well as my new clutch in the next week or so. I'm going to take my time as I don't really drive the car in the winter much anyways. Also going to do the GT2 slave setup and some other maintenance like welding or pinning the fittings and maybe a new water pump. I am going to pull the engine for this. I'm going to build my own exhaust for this setup also. Here is my parts list, let me know if I am missing anything or if there are any surprises. Any advice is appreciated.
the best advice I can give you is to do a pressure test from the turbos to 25 psi b4 you start... then once done ado it again... last car came in with 16gs on it was running 7s in 60 to 130 and now runs a record 5.87... even beat the 18g record... I must have fixed 7 leaks... replaced 2 check valves and TB o ring.... thru on injectors and tune and thats... skip this part and you will be sorry... and the tuner you choose should for you to do it too..
good luck
markski
2001 996TT 3.6L and stock ECU
9.66
seconds @ 147.76 mph 1/4 mile
click to view
Old Dec 20, 2012 | 08:09 PM
SSMugen's Avatar
SSMugen has a reputation beyond reputeSSMugen has a reputation beyond reputeSSMugen has a reputation beyond reputeSSMugen has a reputation beyond reputeSSMugen has a reputation beyond reputeSSMugen has a reputation beyond reputeSSMugen has a reputation beyond reputeSSMugen has a reputation beyond reputeSSMugen has a reputation beyond reputeSSMugen has a reputation beyond reputeSSMugen has a reputation beyond repute
Scrap the intake piping... you might as well get a MAFless tune and when you are ready run the intake pipes right off the turbos then get a bigger Y-pipe and blowoff valves.
Old Dec 20, 2012 | 08:55 PM
John@SpeedTech's Avatar
That's not for everybody - been there, done that, then undid that and went to a high flow plenum/pipe set-up w/ Bosch MAF. Makes the car run just like OEM except with much more power. Various alternative MAF options make the car behave differently. IMO, it would be best to get a few hours of seat time before making dramatic changes like that...
991.2 Turbo S GT Silver
991.2 GT3 Chalk (Manual)
2022 Cayenne White
www.speedtechexhausts.com
info@speedtechexhausts.com
Old Dec 20, 2012 | 11:25 PM
brnrdtns's Avatar
brnrdtns Is a GOD !brnrdtns Is a GOD !brnrdtns Is a GOD !brnrdtns Is a GOD !brnrdtns Is a GOD !brnrdtns Is a GOD !brnrdtns Is a GOD !brnrdtns Is a GOD !brnrdtns Is a GOD !brnrdtns Is a GOD !brnrdtns Is a GOD !
good luck
markski
Thanks, I'm pretty sure I have a leak now, I hear something.
Old Dec 21, 2012 | 05:15 AM
PAULIEWALNUTS's Avatar
PAULIEWALNUTS Is a GOD !PAULIEWALNUTS Is a GOD !PAULIEWALNUTS Is a GOD !PAULIEWALNUTS Is a GOD !PAULIEWALNUTS Is a GOD !PAULIEWALNUTS Is a GOD !PAULIEWALNUTS Is a GOD !PAULIEWALNUTS Is a GOD !PAULIEWALNUTS Is a GOD !PAULIEWALNUTS Is a GOD !PAULIEWALNUTS Is a GOD !
good luck
markski
I believe Chris Green ran a 5.18 60-130 with 18's.
Old Dec 21, 2012 | 06:15 AM
ttboost's Avatar
There is a lot of potential with 18g's. 600whp is very easy to achieve. Might need meth or race gas though. Hard to reach on pump alone. of course, depending on what dyno you are using....We got alomst 600whp (596?) on a Mustang dyno with 18g's and, Injectors and Meth. Race gas put it WAY over...This was with stock aoirbox, all stock piping, stock MAF and stock paper filter...so it can be done.
Old Dec 21, 2012 | 07:48 AM
BlackHorseTurbo's Avatar
BlackHorseTurbo Is a GOD !BlackHorseTurbo Is a GOD !BlackHorseTurbo Is a GOD !BlackHorseTurbo Is a GOD !BlackHorseTurbo Is a GOD !BlackHorseTurbo Is a GOD !BlackHorseTurbo Is a GOD !BlackHorseTurbo Is a GOD !BlackHorseTurbo Is a GOD !BlackHorseTurbo Is a GOD !BlackHorseTurbo Is a GOD !
That was on Unicorn Tears.
Old Dec 21, 2012 | 09:28 AM
johnspeed's Avatar
You are right on with depending on who's dyno...
AWD Mustang I made 549HP, Dyna Packs rear wheel 626HP, DynoJet rear wheel 600HP, All on 93 pump gas..
Old Dec 21, 2012 | 12:33 PM
brnrdtns's Avatar
Any DIY threads on pulling the motor? I've done different cars but never a 911.
Old Dec 21, 2012 | 02:15 PM
TurboTodd's Avatar
TurboTodd has a reputation beyond reputeTurboTodd has a reputation beyond reputeTurboTodd has a reputation beyond reputeTurboTodd has a reputation beyond reputeTurboTodd has a reputation beyond reputeTurboTodd has a reputation beyond reputeTurboTodd has a reputation beyond reputeTurboTodd has a reputation beyond reputeTurboTodd has a reputation beyond reputeTurboTodd has a reputation beyond reputeTurboTodd has a reputation beyond repute
refer back to post #3
Old Dec 21, 2012 | 02:29 PM
I think your right... but this member ran it on 100 with a splash of 109 on injectors, ICs, stock intake to turbos, and a 200 cat exhaust thats 2.5"...
My point was: a well prepped car without leaks is often more important then various extra parts... something most forget and or do not... then when they run BS times they point the finger to the tune or parts ...
9.66
click to view
adnanm3
Nov 22, 2023 02:43 AM
PV=nRT.
Sep 9, 2022 06:06 PM
Rguy
Apr 12, 2020 11:11 PM
ModBargains
997 Turbo Vendor Classifieds
Oct 13, 2015 03:55 PM
ModBargains
997 Vendor Classifieds
Oct 13, 2015 03:53 PM
