FM Wired Transmitters and 996tt PCM
I am sure this has been covered before - but hopefully there has been some progress and I am wondering what other's experiences have been.
I would like to integrate my iPhone to my 996tt stereo system.
The Denon solution seems a little radical and expensive and I dont need all of the functionality - just want to play music.
It seems like a wired FM transmitter is the best option (right?)
...iSimple seems to have a model with a switch that can turn off the external FM antenna which in theory provides better signal - and a AUX and USB power port (I dont think music can be played thru the USB port)
Is this something that I can install myself (how do I get to it?)
any thoughts, insights, experiences - good and bad... on this project.
Here is what I did.
http://www.ebay.com/itm/PORSCHE-8-PI...47e455&vxp=mtr
Didn't order from that seller but its that cable. As long as you have the cdr220 it will plug right in and work. Don't forget to set aux mode in the menu.
I then to go completely wireless added this.
http://www.ebay.com/itm/Miccus-BluBr...item20ce3b92f9
Again, not from that buyer either. It will sync to your Bluetooth and play whatever you play on your phone. I hid it all behind the radio and is completely invisible. FM Transmitter is like listening to AM radio. Don't do it. Better to listen to your engine at that point. Good luck.
Oct 27, 2015 04:49 PM
Oct 7, 2015 12:55 PM
