Can you disable exhaust signal from cats when..
Old Oct 28, 2003 | 06:36 AM
dkc_gt2's Avatar
dkc_gt2 is infamous around these parts
you are running temporary cat bypass pipes for the track and prevents the check engine light to come on.
Old Oct 28, 2003 | 07:47 AM
Joe West's Avatar
Joe West is infamous around these parts
It could be done by reprogramming the ECU... but to do so would cause the emissions control system to be running open loop. Implementation of ECU modifications would be extremely difficult for most individuals.
A much better solution would be to run 100 cell racing cats with a muffler bypass for racing.
Kind Regards,
Joe West
Old Oct 28, 2003 | 08:39 AM
skaria's Avatar
skaria is infamous around these parts
In my previous car, when I ran cat-bypass pipes which had a mounting point for the 02 sensors post catalytic converter, the tech simply wrapped the sensor with aluminium foil before putting it in the mount. The post cat 02 sensor was not used for any of the engine management maps anyway, just there for emissions for the OBDII specification.
This might not be the case with the 996TT, but it is simple to try.
jyupitt1
Sep 23, 2015 06:26 AM
km90265
Aug 31, 2015 11:00 AM
