Tiptronic Upgrade
Old Jan 14, 2013 | 01:41 PM
Snowczar's Avatar
Snowczar is a splendid one to beholdSnowczar is a splendid one to beholdSnowczar is a splendid one to beholdSnowczar is a splendid one to beholdSnowczar is a splendid one to beholdSnowczar is a splendid one to beholdSnowczar is a splendid one to behold
My 996 TT Tip has the EVOMS upgrades and I also got a Transmission chip upgrade. I have about 575 hp according to EVOMS and they indicate the Tip can take much more than that. Check with them.
John in Vancouver
Old Jan 14, 2013 | 09:17 PM
machinegunt's Avatar
machinegunt Is a GOD !machinegunt Is a GOD !machinegunt Is a GOD !machinegunt Is a GOD !machinegunt Is a GOD !machinegunt Is a GOD !machinegunt Is a GOD !machinegunt Is a GOD !machinegunt Is a GOD !machinegunt Is a GOD !machinegunt Is a GOD !
John in Vancouver
I have heard several people say they could not see any difference with evoms TCU! I had my car tuned in there shop and would of bought one had they told me differently! What upgrades did evoms do to your tranny? I wasn't aware they were beefing up Tips? I know they will do the torque converter but thought that was all! ToddZ tuned my car and it put down a very conservative 589HP and 605TQ at the crank on 91 pump! I thought they really didn't feel comfortable putting any more HP through the Tip! I could be wrong though!
Old Jan 15, 2013 | 12:22 PM
Luke_01's Avatar
Luke_01 is infamous around these parts
Thanks guys
I will contact everybody that has been mentioned in this thread.
Old Jan 15, 2013 | 12:25 PM
BlackHorseTurbo's Avatar
BlackHorseTurbo Is a GOD !BlackHorseTurbo Is a GOD !BlackHorseTurbo Is a GOD !BlackHorseTurbo Is a GOD !BlackHorseTurbo Is a GOD !BlackHorseTurbo Is a GOD !BlackHorseTurbo Is a GOD !BlackHorseTurbo Is a GOD !BlackHorseTurbo Is a GOD !BlackHorseTurbo Is a GOD !BlackHorseTurbo Is a GOD !
Originally Posted by Luke_01
Thanks guys
I do however recommend adding a modified torque converter. I think mine was 3000rpm. Helps greatly with dig races and launches at the 1/4 track.
Old Jan 15, 2013 | 05:12 PM
Reeve's Avatar
Reeve is infamous around these parts
To add a quick question, is there any way to decrease shift time on the tiptronic? I drove a Ferrari 458 Italia, and YES, I know it's not this car, but the paddle shifters were changing gears in split seconds, whereas the 996TT I have seems like the same shifting speed my Acura paddle shifters has...
Old Jan 15, 2013 | 05:46 PM
Some claim that the TCU flash helps with shift times. It did not help mine.
Ferrari 458 has a dual-clutch 7-speed GETRAG gearbox.
996TT has an automatic slush box out of a Mercedes Benz.
Old Jan 15, 2013 | 08:25 PM
pumptech's Avatar
pumptech has a reputation beyond reputepumptech has a reputation beyond reputepumptech has a reputation beyond reputepumptech has a reputation beyond reputepumptech has a reputation beyond reputepumptech has a reputation beyond reputepumptech has a reputation beyond reputepumptech has a reputation beyond reputepumptech has a reputation beyond reputepumptech has a reputation beyond reputepumptech has a reputation beyond repute
quick shifts are going to come with valve body work. IPT rebuilds VB's. not sure if its part of standard upgrade or if its extra. also a place called valve body builders said they could easily do it. fix euro said they dont specifically do it but have someone in dallas they would use if desired. the actually discouraged it tho as the concern was the ability of the TCU to handle the changes and any reprogramming required. there are aslo some solenoids that can be upgraded once the VB is accessed.
you guys are not doing your homework. most of the info is out there. start here https://www.6speedonline.com/forums/...on-thread.html
Old Jan 16, 2013 | 11:20 AM
waymegelli's Avatar
waymegelli is a jewel in the roughwaymegelli is a jewel in the roughwaymegelli is a jewel in the roughwaymegelli is a jewel in the rough
Jumping back to the OP
I put 3071s on my 2002, plus injectors, aux fuel pump and a few other mods, and Motorwerks Houston did an upgrade to my tip for $6K. It involved additional plates and other "propriatary" mods. I'm not sure how much HP I've got, but I haven't had any problem with it in about 1500 miles. I know it's not a lot of miles, but it's all I can attest to. I understand Motorwerks is no longer around, or at least not with the same mechanics, so I don't think they are an option for the OP.
Old Jan 16, 2013 | 10:07 PM
pat's Avatar
pat
pat has a reputation beyond reputepat has a reputation beyond reputepat has a reputation beyond reputepat has a reputation beyond reputepat has a reputation beyond reputepat has a reputation beyond reputepat has a reputation beyond reputepat has a reputation beyond reputepat has a reputation beyond reputepat has a reputation beyond reputepat has a reputation beyond repute
I also have collected a bunch of info on this thread. My problem is still unresolved . And will be getting back to it over the winter.
https://www.6speedonline.com/forums/...1-pd-code.html
Old Jan 16, 2013 | 10:33 PM
salerno713's Avatar
salerno713 has much to be proud ofsalerno713 has much to be proud ofsalerno713 has much to be proud ofsalerno713 has much to be proud ofsalerno713 has much to be proud ofsalerno713 has much to be proud ofsalerno713 has much to be proud ofsalerno713 has much to be proud of
Fellas, anyone use an additional trans cooler? Keeping temps down helps a ton. Upgraded additional clutch packs are added into Renntechs trans pkg. Not a bad idea adding the raised torque converter either.
Old Jan 16, 2013 | 10:59 PM
bad107's Avatar
bad107 has a reputation beyond reputebad107 has a reputation beyond reputebad107 has a reputation beyond reputebad107 has a reputation beyond reputebad107 has a reputation beyond reputebad107 has a reputation beyond reputebad107 has a reputation beyond reputebad107 has a reputation beyond reputebad107 has a reputation beyond reputebad107 has a reputation beyond reputebad107 has a reputation beyond repute
tranny cooler not really needed unless you track your tip, but not sure who actually tracks their tip lol
Old Jan 17, 2013 | 07:27 AM
pumptech's Avatar
FixEuro recommended a custom trans oil pan to hold more fluid and thought that would help better than a cooler in most instances. Said they could probably have it made if desired and clearance permitting.
Old Jan 17, 2013 | 12:51 PM
ysfg35's Avatar
ysfg35 Is a GOD !ysfg35 Is a GOD !ysfg35 Is a GOD !ysfg35 Is a GOD !ysfg35 Is a GOD !ysfg35 Is a GOD !ysfg35 Is a GOD !ysfg35 Is a GOD !ysfg35 Is a GOD !ysfg35 Is a GOD !ysfg35 Is a GOD !
you can ask emre@esmotor
he is a vender here , i built my tip 997 turbo by him 2 years ago , sero issues till now
running high boost weekly
Old Jan 18, 2013 | 01:50 PM
Luke_01's Avatar
YSFG35.
What kind of WHP do you have there?
Old Jan 19, 2013 | 09:45 AM
Snowczar's Avatar
I just had the the TCU software upgraded to match up with the ECU upgrade and full exhaust and MAF system changes. I do notice that the shifts are a little more crisp. EVOMS indicated the transmission itself can handle way more torque/hp than I am getting.
John in Vancouver
