High Idle
Old Jan 25, 2013 | 08:34 PM
Schwolneck's Avatar
Schwolneck is infamous around these parts
High Idle
I am getting a higher than normal idle once the car has been driven for about 10 minutes, it idles around 1000 RPM's to 1100 RPM's. I will get a CEL after driving it for a couple of days, check the codes and it states" idle higher than normal", anyone have any ideas of what to check first?
Old Jan 25, 2013 | 10:44 PM
johnspeed's Avatar
When you say after 10 minutes,,Is that from it starting being cold to warm up?
Old Jan 25, 2013 | 11:52 PM
unvmy996's Avatar
If you turn the ac on does the idle drop? If so it's a vacume leak
Old Mar 18, 2013 | 01:52 PM
Luke_01's Avatar
Luke_01 is infamous around these parts
My TT started to idle high (1200 RPM) as well and it returns to normal (800 RMP) when I switch the AC on. It is also sometimes hunting wile idling. Can anyone direct me as to how to find a vacuum leak if that is what is causing it? Any other ideas out there?
Much appreciated.
nlakind
Nov 6, 2015 10:15 AM
03EvoIII
Sep 21, 2015 04:38 PM
turbotuner20v
Sep 11, 2015 12:02 PM
EMC2
Cayenne 955/957
Sep 7, 2015 05:20 PM
