Updated inlet or y pipe system
Old Feb 17, 2013 | 10:49 PM
johnspeed's Avatar
Originally Posted by SSMugen
Have you seen a car w/ the inlet pipes on them? You can clearly see the plenum when you look next to the fuel filter ... If you are concerned with the dealership seeing the pipes you might want to go with the pipes that attach to the stock restrictive plenum.
Short intake pipes would be seen easily by the dealer.
My car was tuned by Todd at Protomotive and makes very good power and better throttle response with the 'Restrictive' plenum over any fender well intake system near my HP level I have been in....It all depends at the mod/HP level that you are at to fully use that system..
I have over 40,000 miles on my original MAF and go to 7400 RPM..
To each his own, its all good..
Old Feb 18, 2013 | 12:09 AM
GT996's Avatar
GT996 has a reputation beyond reputeGT996 has a reputation beyond reputeGT996 has a reputation beyond reputeGT996 has a reputation beyond reputeGT996 has a reputation beyond reputeGT996 has a reputation beyond reputeGT996 has a reputation beyond reputeGT996 has a reputation beyond reputeGT996 has a reputation beyond reputeGT996 has a reputation beyond reputeGT996 has a reputation beyond repute
Hi,
Originally Posted by John@SpeedTech
Here is my reason why:
I tried them and from my direct experience, the alternate MAF's change the driving characteristics/behavior of the fuel delivery and smoothness of the car.
probably the confusion here is that a MAFless tune has no MAF that could behave differently. There is no MAF at all. Your experience might be that from a blow thru system?
Regards,
Andreas
Old Feb 18, 2013 | 12:15 AM
johnspeed's Avatar
Sorry,I thought you were talking about a blow through set-up..
Old Feb 18, 2013 | 12:37 AM
John@SpeedTech's Avatar
Originally Posted by GT996
Hi,
Regards,
Andreas
Yes. Also what I thought was being commented on...
991.2 Turbo S GT Silver
991.2 GT3 Chalk (Manual)
2022 Cayenne White
www.speedtechexhausts.com
info@speedtechexhausts.com
Old Feb 18, 2013 | 12:05 PM
earl3's Avatar
earl3 Is a GOD !earl3 Is a GOD !earl3 Is a GOD !earl3 Is a GOD !earl3 Is a GOD !earl3 Is a GOD !earl3 Is a GOD !earl3 Is a GOD !earl3 Is a GOD !earl3 Is a GOD !earl3 Is a GOD !
Originally Posted by Bobbyfali
How is that possible to run 147mph on any type of 18g's or new billets!!!! That over 900bhp, the 18g's can't flow that, unless the car is making 750bhp and weighs under 2500lbs.
Is there a thread I can read up on this persons car. If he is running that MPH out of those turbos, there is a lot I can learn off his build!
Please forward me more info on his car!
Bobby Ali
ba
Here ya go Bobby:
https://www.6speedonline.com/forums/...-146-65-a.html
E85 car with lots of boost and eventually bent rods. All with that horrible bottleneck y-pipe in place
Old Feb 18, 2013 | 01:20 PM
johnspeed's Avatar
Originally Posted by earl3
Here ya go Bobby:
And stock plenum and stock throttle body..
Old Feb 18, 2013 | 02:42 PM
I think Chris did a back to back and the inlet pies made 30 whp... if Im not mistaken he made a post about it... but again , each set u is different... I know that Todd at proto did a back to back on 18gs and it made 35 whp more at 1.35 bar...
I had a set of them in 2002 form FVD... I honestly think that its the most overlooked upgrade to date... but thats just me...
2001 996TT 3.6L and stock ECU
9.66
seconds @ 147.76 mph 1/4 mile
click to view
Old Feb 18, 2013 | 10:30 PM
Ms4cd's Avatar
Ms4cd has a reputation beyond reputeMs4cd has a reputation beyond reputeMs4cd has a reputation beyond reputeMs4cd has a reputation beyond reputeMs4cd has a reputation beyond reputeMs4cd has a reputation beyond reputeMs4cd has a reputation beyond reputeMs4cd has a reputation beyond reputeMs4cd has a reputation beyond reputeMs4cd has a reputation beyond reputeMs4cd has a reputation beyond repute
I agree, confirmed similar gains when I installed mine.
Old Feb 19, 2013 | 08:00 AM
johnspeed's Avatar
On my set-up it did show hardly any improvement But I had a 200 cell Cargraphic exhaust on it then which I found out later to be restrictive for my 18gs pump gas set up.
It's all in the combo of mods, results may very.
Old Aug 12, 2016 | 06:00 AM
samugtmadrid's Avatar
samugtmadrid is infamous around these parts
Hi,
Regards,
Andreas
I read the post and can not find the solution to my problem :-( I read that I can put a maf ford and all sorted but not that model ford is, and that goes well with maf ford? is designed to provide more air ?
Old Aug 12, 2016 | 06:13 AM
BauerR's Avatar
BauerR Is a GOD !BauerR Is a GOD !BauerR Is a GOD !BauerR Is a GOD !BauerR Is a GOD !BauerR Is a GOD !BauerR Is a GOD !BauerR Is a GOD !BauerR Is a GOD !BauerR Is a GOD !BauerR Is a GOD !
You couldn't pay be to go back to a MAF setup. With ditching the OEM intake tract completely, my car woke up like no other mod Ive done to date.
The way my car runs, I would go out on a limb and say I have the fastest stock turbo 996 out there today.
Mind you, I have no real data on that(1/4 mile runs or dyno) but I'm happy for anyone to attempt to prove me otherwise.
orbelo
Aug 30, 2015 12:26 PM
John@SpeedTech
Aug 23, 2015 12:07 AM
Fabspeed Motorsport
Audi
Aug 21, 2015 11:30 AM
HolmaN
Aug 18, 2015 01:35 PM
