She's going under the knife tomorrow
Old Feb 23, 2013 | 10:37 AM
Bobbyfali's Avatar
Bobbyfali Is a GOD !Bobbyfali Is a GOD !Bobbyfali Is a GOD !Bobbyfali Is a GOD !Bobbyfali Is a GOD !Bobbyfali Is a GOD !Bobbyfali Is a GOD !Bobbyfali Is a GOD !Bobbyfali Is a GOD !Bobbyfali Is a GOD !Bobbyfali Is a GOD !
Originally Posted by ysfg35
Why not a3071 or a3076 ?? You will get more power ..
Whats the HP target for your project ?
Good luck .. Hope you enjoy it
Originally Posted by PAULIEWALNUTS
How much whp would you go on a stock block?
24/20's will get you above the 700whp mark.
I have not seen many 3071's or 3076's that go past the 700 whp mark.
Some one bring some clarity on this 24/20's BILLET's making more power then 3076's???
I always thought that the k24 based would take longer to spool and make less then a 3071 or 3076.
If that is not the case why would people waste money on a FULL turbo upgrade for $4500+ when they can make more power on stock based stuff for far less like $3000 (including buying a k24 cores for $1100 & $1900 for upgrade and wastegates from 911Tunning)???
If there is some hard facts about your statement, I think I found my next upgrade....as in I can do this ASAP up grade!!
Bobby Ali
ba
Old Feb 23, 2013 | 11:35 AM
unvmy996's Avatar
uhh... im not sure on 3071's but 3076's will get you very well into the 700 mark..and they are supperior turbo then the 20g. and will get you there with less boost..
i had both.... in order for the 20 to shine it needs race fuel or e85 and lots of boost.... boost for boost the 3076 turbo is a better option.
Old Feb 23, 2013 | 12:01 PM
PAULIEWALNUTS's Avatar
PAULIEWALNUTS Is a GOD !PAULIEWALNUTS Is a GOD !PAULIEWALNUTS Is a GOD !PAULIEWALNUTS Is a GOD !PAULIEWALNUTS Is a GOD !PAULIEWALNUTS Is a GOD !PAULIEWALNUTS Is a GOD !PAULIEWALNUTS Is a GOD !PAULIEWALNUTS Is a GOD !PAULIEWALNUTS Is a GOD !PAULIEWALNUTS Is a GOD !
Agreed the 24/20's shine when boost is 1.6bar using ms 109 fuel.
Using the 3076's should get you to the 700 mark with less boost.
The billet 20's spool as fast if not faster than my old 24/18's. I have no comparison to the 3076's.
Good luck with the ones you choose.
Old Feb 23, 2013 | 03:37 PM
triblk6spd's Avatar
triblk6spd has a reputation beyond reputetriblk6spd has a reputation beyond reputetriblk6spd has a reputation beyond reputetriblk6spd has a reputation beyond reputetriblk6spd has a reputation beyond reputetriblk6spd has a reputation beyond reputetriblk6spd has a reputation beyond reputetriblk6spd has a reputation beyond reputetriblk6spd has a reputation beyond reputetriblk6spd has a reputation beyond reputetriblk6spd has a reputation beyond repute
Can you comment on the difference in lag between the two set-ups? I found the lag w my 30/76's to be pretty annoying.
Old Feb 23, 2013 | 04:31 PM
unvmy996's Avatar
With the right supporting mods lag shouldn't be that much different .i noticed very little difference if any...
But everyone always talks about lag this or that ... I could care less... All you have to do is down shift be in the right gear or rpm.. I mean if your on the highway in 6 th cruising just throw it down one .. And bam no lag
Old Feb 23, 2013 | 05:06 PM
95RogueM3's Avatar
95RogueM3 has much to be proud of95RogueM3 has much to be proud of95RogueM3 has much to be proud of95RogueM3 has much to be proud of95RogueM3 has much to be proud of95RogueM3 has much to be proud of95RogueM3 has much to be proud of95RogueM3 has much to be proud of95RogueM3 has much to be proud of
While yes there is the saying, "If you experience lag, you are in the wrong gear...", there is something to be said for a super responsive turbo that builds boost nearly instantly. I continue to go back and forth in my mind on the K24/18g or Billet K16 route for that very reason...
Old Feb 23, 2013 | 05:29 PM
32krazy!'s Avatar
i was hoping you would go the force performance route so i could see how they perform on 93 oct!
Old Feb 23, 2013 | 06:34 PM
unvmy996's Avatar
I would do the 18g's if I were you..
Old Feb 23, 2013 | 07:02 PM
95RogueM3's Avatar
They sounded like a bit too much. I'll let you have the honor of being the first to take that route.
Old Feb 23, 2013 | 11:36 PM
unvmy996's Avatar
Which FP turbos are you talking about krazy?
Old Feb 24, 2013 | 02:03 AM
32krazy!'s Avatar
force performance will build a k24 turbo with a hta68 wheel extended tips and port and polish for 2400$ with cores. they machine the oem housing to fit the 68 wheel and im interested but its the most expensive of any k24 build i have seen. 3 week lead time
Old Feb 24, 2013 | 09:17 AM
unvmy996's Avatar
hmm very interesting ... first i hear of this , what are these rate for do you know?
Old Feb 24, 2013 | 11:33 AM
32krazy!'s Avatar
not positive but should be capable of 700 hp
Old Feb 24, 2013 | 12:17 PM
earl3's Avatar
earl3 Is a GOD !earl3 Is a GOD !earl3 Is a GOD !earl3 Is a GOD !earl3 Is a GOD !earl3 Is a GOD !earl3 Is a GOD !earl3 Is a GOD !earl3 Is a GOD !earl3 Is a GOD !earl3 Is a GOD !
A claimed 48 lb/min but no published compressor maps. AFAIK the flow #s are back calculated based on dyno performance on various platforms (mainly Evo) ...all of this IF not crammed into a "way too small for this compressor" K24 housing. This is why Champion does custom housings with these wheels on their VTGs (similar compressor housing limitations). They have hit over 700rwhp (dynojet) for a few seconds with the more restrictive (vs K24) VTG hotside though.
Kevwood
Jan 7, 2016 10:49 AM
djantlive
Charity Notices/Events
Sep 26, 2015 01:25 PM
carlosC4S
Cayenne 958
Sep 26, 2015 08:58 AM
Yogi911
Sep 9, 2015 08:20 PM
