Alternator - R.I.P
Old Feb 27, 2013 | 02:38 PM
hroussard's Avatar
hroussard Is a GOD !hroussard Is a GOD !hroussard Is a GOD !hroussard Is a GOD !hroussard Is a GOD !hroussard Is a GOD !hroussard Is a GOD !hroussard Is a GOD !hroussard Is a GOD !hroussard Is a GOD !hroussard Is a GOD !
Alternator - R.I.P
After 26K miles, my alternator decided to quit working. The voltage gauge started to show less charge a few weeks ago, barely 13Volts.. I started to plug in the battery conditioner overnight... Situation got worse and the charge dropped down to 12V within the span of a few days. Got it replaced total bill 1,000 dollars including the overhauled alternator. It's a 2003 996TT but come-on folks, an alternator failing after 26K miles ( always garaged, no winters, no snow, little rain). They do not make them the way they used to!
Old Feb 27, 2013 | 05:17 PM
SSMugen's Avatar
SSMugen has a reputation beyond reputeSSMugen has a reputation beyond reputeSSMugen has a reputation beyond reputeSSMugen has a reputation beyond reputeSSMugen has a reputation beyond reputeSSMugen has a reputation beyond reputeSSMugen has a reputation beyond reputeSSMugen has a reputation beyond reputeSSMugen has a reputation beyond reputeSSMugen has a reputation beyond reputeSSMugen has a reputation beyond repute
Mine died a couple weeks ago. Found a hookup on a new bosch alternator for $560 and 1hr 45mins later had it back up and running. Just a heads up to people that need a new alternator do some research and see if you want to do it yourself. It's really not that hard.
Old Feb 27, 2013 | 05:57 PM
LQQK's Avatar
LQQK has a reputation beyond reputeLQQK has a reputation beyond reputeLQQK has a reputation beyond reputeLQQK has a reputation beyond reputeLQQK has a reputation beyond reputeLQQK has a reputation beyond reputeLQQK has a reputation beyond reputeLQQK has a reputation beyond reputeLQQK has a reputation beyond reputeLQQK has a reputation beyond reputeLQQK has a reputation beyond repute
I did mine a couple of months back as a precaution. Wasn't difficult at all. Do the belt at the same time.
Also, I purchased a 997 alternator (make sure its not a tip as the pulley is different). The 997 has a few more amps than the 996.
I have my old one in a box if you hard up and looking for something. Just let me know.
Old Feb 27, 2013 | 07:05 PM
deckman's Avatar
Wow that is a lot of coin. I bought a rebuilt one for about $300 and replaced it myself. I have a feeling it was the regulator, which I think is a common failure. I'm going to replace that and if there's another failure try putting it back in.
Old Feb 27, 2013 | 11:45 PM
gearhead's Avatar
gearhead has a reputation beyond reputegearhead has a reputation beyond reputegearhead has a reputation beyond reputegearhead has a reputation beyond reputegearhead has a reputation beyond reputegearhead has a reputation beyond reputegearhead has a reputation beyond reputegearhead has a reputation beyond reputegearhead has a reputation beyond reputegearhead has a reputation beyond reputegearhead has a reputation beyond repute
Man I got a deal then. $300 after taxes for a new not rebuild Bosch alternator. In canada, at my local parts shop.
Old Feb 28, 2013 | 12:09 AM
jpflip's Avatar
Most of the time it is only the voltage regulator that need to be replace. Easy job and only $20.00.....
Old Feb 28, 2013 | 12:56 AM
birgppa's Avatar
birgppa is infamous around these parts
That's horrible after 26k only At least you should be glad it's not an italian car, would probably cost you 5 times the money!
Old May 8, 2013 | 06:54 AM
gillrich's Avatar
gillrich is infamous around these parts
New to forum. Have 02' Turbo with only 13K miles and alternator showing <13 volts and dropping. Sounds like voltage reg. Didn't know reg. was a replaceable item as it's an integral part of alt. Maybe Jpflig can expand on reg. replacement details? In any event, alt. replacement sounds like it may not be as bad as I think.
Old May 8, 2013 | 07:31 AM
i have a perfectly working low mile alternator u can have for 200$
#TeamAIM
Old May 8, 2013 | 07:40 AM
gillrich's Avatar
I may take you up on that alternator, prodigymb. Want to do further checking first to confirm it is isolated to the alternator. I know it's not a battery issue (replaced yesterday) but have some concerns about cable heat resistance I read in forum. I will let you know...
Old May 8, 2013 | 07:50 AM
Steve Jarvis's Avatar
Steve Jarvis Is a GOD !Steve Jarvis Is a GOD !Steve Jarvis Is a GOD !Steve Jarvis Is a GOD !Steve Jarvis Is a GOD !Steve Jarvis Is a GOD !Steve Jarvis Is a GOD !Steve Jarvis Is a GOD !Steve Jarvis Is a GOD !Steve Jarvis Is a GOD !Steve Jarvis Is a GOD !
That's crazy, the last two alternators I replaced were on my Supra and M3. Both had lasted over 100,000 miles on them.
I wonder if it's due to the amount of time these cars typically sit?
Later, Steve
Old May 8, 2013 | 08:38 AM
jpflip's Avatar
gillrich, my problem was exactly like yours and replacing the regulator fix it.....The voltage regulator can be replaced and it is very easy. The hardest part is to remove the alternator but not too difficult.
You will found here info regarding alternator replacement and voltage regulator replacement and all the part# needed on the Pelican site. https://www.6speedonline.com/forums/...e-replace.html
http://forums.rennlist.com/rennforum...d-alt-reg.html
http://forums.pelicanparts.com/porsc...placement.html
Old May 8, 2013 | 08:56 AM
The Pork Hunt's Avatar
The Pork Hunt has a reputation beyond reputeThe Pork Hunt has a reputation beyond reputeThe Pork Hunt has a reputation beyond reputeThe Pork Hunt has a reputation beyond reputeThe Pork Hunt has a reputation beyond reputeThe Pork Hunt has a reputation beyond reputeThe Pork Hunt has a reputation beyond reputeThe Pork Hunt has a reputation beyond reputeThe Pork Hunt has a reputation beyond reputeThe Pork Hunt has a reputation beyond reputeThe Pork Hunt has a reputation beyond repute
Alternator voltage regulators:
Wood Auto
part number is VRG46444-~$80 (not from dealer)
Bosch regulator
Bosch interchange part number: F00M-145-350 (which supercedes PNs: F-00M-145-200, F-00M-145-209 and F-00M-145-225)
Porsche part number: 000-043-206-37-M14
Bosch catalog with information: http://www.bosch.co.nz/content/langu...pare_Parts.pdf
IAT
part number: 09115
Here is a link with that info:
http://www.iat-usa.com/Regulators.pdf
Link with info: alternator voltage regulator
Link to DIY to replace Alternator Voltage Regulator(AKA Generator Circuit Control Module): http://www.renntech.org/forums/index...rcuit-control/
VAGscum posted this in the Knowledge Base thread, I used it to change my voltage reg. last year. Almost guarantee that's what your problem is, the rotor assembly is very solid unit. Chances are the brushes are becoming worn and need to be replaced, these are attached to the voltage reg. unit. It's an easy job to do though, biggest issue was the alternator was fit very well into its mount, haha. Took me a bit of cursing and a beer or two, but I eventually managed to weasel it out. Put the new voltage reg. in, put her back together and Robert's your fathers brother.
Old May 8, 2013 | 09:35 AM
gillrich's Avatar
Good info. JPflip. I will followup accordingly with this option. Thanks.....
Old May 8, 2013 | 09:41 AM
jpflip's Avatar
Welcome!!!
