O2 sensor location
Old Mar 4, 2013 | 10:19 PM
quick968's Avatar
quick968 is a jewel in the roughquick968 is a jewel in the roughquick968 is a jewel in the roughquick968 is a jewel in the rough
O2 sensor location
OK, after a full days driving, got a CEL. I MAY have mixed up the O2 sensors locations installing the new cats. By any chance can anyone tell me which sensor goes in which position? I currently have the the sensor with the GRAY wiring cover installed AFTER the cat, and the sensor with the BLACK wiring cover installed BEFORE the cat, just after the turbos. Right? Wrong?
Cheers
Mikey
Old Mar 4, 2013 | 11:40 PM
thats correct... make sure both sides are the same..
Im guessing its the cat thats causing the issue...
2001 996TT 3.6L and stock ECU
9.66
seconds @ 147.76 mph 1/4 mile
click to view
Old Mar 5, 2013 | 12:20 PM
Macster's Avatar
Agree.
OP: what is the error code associated with the CEL?
Old Mar 5, 2013 | 08:57 PM
quick968's Avatar
Originally Posted by Macster
Agree.
Durametric shows:
P1145 O2 sensor ahead of cat conv. Cylinder (1-3) exceeds limit value
P1155 O2 sensor ahead of cat conv. Cylinder (4-6) exceeds limit value
So, does that mean I actually DO have the O2 sensors mixed up?
Cheers
Mikey
Old Mar 6, 2013 | 11:40 AM
f1crazydriver's Avatar
f1crazydriver Is a GOD !f1crazydriver Is a GOD !f1crazydriver Is a GOD !f1crazydriver Is a GOD !f1crazydriver Is a GOD !f1crazydriver Is a GOD !f1crazydriver Is a GOD !f1crazydriver Is a GOD !f1crazydriver Is a GOD !f1crazydriver Is a GOD !f1crazydriver Is a GOD !
Mike,
The 02 sensor's with the black/grey/white wires are for the rear. The color coded wires are the ones that go in the front.
Lift yo the cover's and you will be able to see the wires... Sorry for not getting back to you earlier. I willl shot you an email right now.
Old Mar 6, 2013 | 12:57 PM
quick968's Avatar
Thanks Enrique! I'll take a look again tonight, I'm thinking I may have em both backwards. I'll update you on progress.
Cheers
Mikey
Old Jun 17, 2014 | 06:14 PM
brow0814's Avatar
brow0814 is infamous around these parts
Quick- did you get this reconciled??
thanks.
Scott
Old Jun 18, 2014 | 05:09 PM
quick968's Avatar
Yep, Enrique got me fixed up. Wow, that was over a year ago.
Mikey
Lowtush
Jan 25, 2022 10:48 AM
RallyBird
Oct 7, 2015 01:20 PM
LiquidElephant
Aug 27, 2015 06:17 PM
riozilla
Aug 21, 2015 11:34 PM
Aug 19, 2015 06:35 PM
