Lw battery vs stock battery
Old Mar 8, 2013 | 10:00 AM
Bobbyfali's Avatar
Bobbyfali Is a GOD !Bobbyfali Is a GOD !Bobbyfali Is a GOD !Bobbyfali Is a GOD !Bobbyfali Is a GOD !Bobbyfali Is a GOD !Bobbyfali Is a GOD !Bobbyfali Is a GOD !Bobbyfali Is a GOD !Bobbyfali Is a GOD !Bobbyfali Is a GOD !
I was wondering what real life issues I might run into with running this battery over stock:Braille B2618. 18.5lbs vs 57lbs stock
http://www.sportscarboutique.com/col...cing-Batteries
Part # B2317 B2317RP B2618 B3121
PCA 1191 1191 1168 1380
CA 641 641 626 742
CCA 475 475 472 550
Amp Hr 23 23 26 31
Length 6.8" 6.8" 8.1" 6.6"
Width 4.0" 4.0" 3.5" 5.2"
Height 6.1" 6.1" 6.3" 6.8"
Weight 17Ibs 17Ibs 18.5Ibs 21Ibs
Wnty 2 yr 2 yr 2 yr 2 yr
Positive Left Right Right Right
In the winter or if my car will be parked more then 2weeks, I will hook my car up to a Battery Tender.
Anyone with real world experience with the switch to a LW battery?
Bobby Ali
ba
Old Mar 8, 2013 | 10:49 AM
f1crazydriver's Avatar
f1crazydriver Is a GOD !f1crazydriver Is a GOD !f1crazydriver Is a GOD !f1crazydriver Is a GOD !f1crazydriver Is a GOD !f1crazydriver Is a GOD !f1crazydriver Is a GOD !f1crazydriver Is a GOD !f1crazydriver Is a GOD !f1crazydriver Is a GOD !f1crazydriver Is a GOD !
odyssey pc925, weight 24lbs... I have had this battery since August - 0 issues. At times i go 2-3 weeks with the car sitting, and cranks everytime 0 issues..and i do not use a battery tender.
  • 925 cranking amps for 5 seconds
  • 870 cranking amps for 10 seconds
  • 765 cranking amps for 20 seconds
  • Short circuit current over 2400A
  • 28 amp hours
  • 50 minute reserve capacity with 25amp load
  • Female brass terminal w/M6 SS bolt
  • Length 6 15/32"
  • Width 6 7/8"
  • Height 4 7/8"
  • Weighs 24 lbs
Odyssey design:
  • Rugged Drycell sealed design
  • Military grade
  • Vibration resistant
  • 60% more starting power
  • Deep discharge reserve power
  • 2 year storage life
  • 8-12 year design life
  • Can be mounted in any orientation
Old Mar 8, 2013 | 11:05 AM
TXTurbo996's Avatar
TXTurbo996 has much to be proud ofTXTurbo996 has much to be proud ofTXTurbo996 has much to be proud ofTXTurbo996 has much to be proud ofTXTurbo996 has much to be proud ofTXTurbo996 has much to be proud ofTXTurbo996 has much to be proud ofTXTurbo996 has much to be proud ofTXTurbo996 has much to be proud of
That Odyssey PC925 is about the smallest I'd go for a lightweight battery. I've used some that were ~15 lbs, and eventually, they lose the ability to hold much of a charge and you have to keep them battery tended all the time, which is a hassle.
I switched to a battery similar to the 925 and it's been far better.
Keep in mind though that our cars already have a heavy rear weight bias... I'd figure out a way to lose some weight in the rear before going with a lightweight battery... an aftermarket exhaust should do nicely.
Old Mar 8, 2013 | 11:08 AM
I agree 100%... only reason for a light battery was to lower a bit the center of gravity, but I still wanted to retain a battery that has capacity of DD that met my needs ... hence the 925.
Old Mar 8, 2013 | 11:23 AM
sinKing's Avatar
sinKing Is a GOD !sinKing Is a GOD !sinKing Is a GOD !sinKing Is a GOD !sinKing Is a GOD !sinKing Is a GOD !sinKing Is a GOD !sinKing Is a GOD !sinKing Is a GOD !sinKing Is a GOD !sinKing Is a GOD !
I just thought of this so haven't looked at my car to see if it seems feasible, but has anybody relocated the battery to where the spare tire normally lives for just this purpose?
Old Mar 8, 2013 | 04:39 PM
pat's Avatar
pat
pat has a reputation beyond reputepat has a reputation beyond reputepat has a reputation beyond reputepat has a reputation beyond reputepat has a reputation beyond reputepat has a reputation beyond reputepat has a reputation beyond reputepat has a reputation beyond reputepat has a reputation beyond reputepat has a reputation beyond reputepat has a reputation beyond repute
https://www.6speedonline.com/forums/...w-battery.html
I run this small one. I only drive in the " driving season " here . No problems but don't leave lights on .
Old Mar 8, 2013 | 05:01 PM
32krazy!'s Avatar
lightest strongest battery on the market. willing to pay the price?
https://p10.secure.hostingprod.com/@...products_id=81
Old Mar 8, 2013 | 05:42 PM
ttboost's Avatar
Way back when, I used a Deka...11lbs. Always left it parked with a battery tender. The ONLY issue I ever had was driving at night for extended periods with the lights on. I would notice them getting dim and my volts gauge would start to dip. Never drove much at night, so never looked into it. Not sure if anyone else ever noticed this.
Old Mar 9, 2013 | 12:03 AM
Bobbyfali's Avatar
Sorry guys, I forgot to say what battery it is. I edited my ORGINAL post to reflect.
Braille B2618 18.5lbs
Bobby Ali
ba
Old Mar 9, 2013 | 06:01 AM
TXTurbo996's Avatar
I think I'd go with the 3121 if I were you. 5 more Ah capacity and it's $30 cheaper, while only weighing 2.5 lbs more.
Old Mar 9, 2013 | 06:14 AM
ttboost's Avatar
I concur...get the most aH you can get, even if it sacrifices a pound or two...you're still losing over 30lbs or more...
Old Mar 9, 2013 | 06:16 AM
ttboost's Avatar
I concur. I would recommend you get all the aH you can get, even if it sacrifices a pound or two...you're still saving over 30lbs...
Old Mar 9, 2013 | 03:41 PM
pat's Avatar
pat
Jul 29, 2019 11:13 AM
DetomasoGTS74
Nov 11, 2015 09:01 AM
The_Ruski_Driver
Oct 25, 2015 08:40 PM
DSCOFF
Aug 23, 2015 01:22 PM
