Engine continues revs after clutch disengaged
SubscribeMy '04 Turbo has done this on occasion and it's extremely irritating. I bought the car with less than 15K miles so I don't think it's anything age or mile related. It feels like a mat slipped under the accelerator and is holding the gas on. Or like the throttle valve is hanging and not closing when your foot is lifted from the gas pedal. A definite lag in timing that makes quick shifting impossible at times. I think it may be E-gas related. My '99 Boxster has never done it, and I've has it for about 12 years. The '99 C2 Cab I had foe 7 years never did it either. If I could switch to a mechanical throttle, I'd do it in a heartbeat.
Quote:
I'll mention the high idle and the vacuum leak to my mechanic. And yeah, I'm already adapting to the 2nd gear popout...the issues so far are discouraging, but at the end of the day it's worth it. As far as the clutch slip, I'm pretty certain it's from the extra power the tune gave me; I tried a few more tests at 4th with WOT, and nothing. Pretty sure it was a cold clutch + 1.2-ish bar of boost...but yeah, Sachs 2.5 coming soon I'm sure.Originally Posted by '02996ttx50
1k is high for idle. should be a steady 750-800 max. when you get these history "less" known, it's best to do the "major" service items eg plugs/coils/gear oil etc to get that stuff out of the way and begin as fresh as you can. unless one has specific problems to deal with first. you may in fact be getting used to certain quirks of the car some of us are already familiar with, though your problems sound unique. but clutch slippage for example, isn't cool no matter what, and i'm assuming you'd know that from normal operating peculiarities.. the ones you will in time come to know and love. it's good to have a good indie, that's for sure. you *may* have a vacuum leak.
Here's to keeping the next mechanic visit under a few thousand $! (sigh)
Quote:
I'll be sure to update this thread when/if I figure out what the problem is. It's not really detrimental (I guess), but it's certainly annoying when you go from a manual where you expect the shifts to behave some way and they act like this.Originally Posted by nick49
I like the throttle valve hanging idea...I don't know how it would happen with drive-by-wire unless the throttle plate controlled by it is being hung up on the throttle body somehow. I'll look into this one....maybe some buildup in the throttle body like 02996ttx50 suggested.
The e-gas is a good theory too; the fact that it doesn't do it unless I'm under boost is suspect though. Thanks for the input.
that would be my choice also. you're right to have the guy check for vac leaks and the tb. a good starting point i would say. if it's any consolation, earlier today i managed to find a small boulder ( though possibly a small meteorite Originally Posted by dubhov
yeah, Sachs 2.5 coming soon I'm sure.Here's to keeping the next mechanic visit under a few thousand $! (sigh)
) with my right front wheel at speed during a brisk canyon run
nothing is under a grand on these cars.... and welcome to the club
dubhov,
similar thing happened to my completed stock low mile (15K) 2001 996TT.
A quick MAF sensor cleaning with a MAF cleaning spray can solved my problem.
Hope it will solve your.
BV
BV
