PS2 tire - from ZR to YR??
Old Jul 20, 2005 | 11:19 AM
limitup's Avatar
limitup has a spectacular aura aboutlimitup has a spectacular aura about
I've got 315/30ZR18 tires on the rear wheels. I got a screw in one of them so I just went to TireRack to order a new tire. However they have the tire listed as a 315/30 *YR* tire. Did Michelin change the tire at some point? More importantly, is it OK to mix this with my 3 other ZR tires??
Old Jul 20, 2005 | 12:32 PM
20C4S's Avatar
i think the Y rating is the new rating system for Z rating tires.
here is good info u might want to check it out:
http://www.tirerack.com/tires/tirete....jsp?techid=35
Old Jul 20, 2005 | 01:40 PM
djantlive's Avatar
Are your other tires pretty new (70% tread remaining at least)? If not, you may consider replacing both on the same axle.
Old Jul 20, 2005 | 01:51 PM
damon@tirerack's Avatar
Moderator
Your tire now is a Y rated tire. Check out the sidewall on it further down from the size. See where it's marked "93Y"? That's the actual speed rating. It may be lister as ZR18 because a Z rating is non-specific to 150 OR MORE miles per hour. Y is rated all the way to 186. So, a Y rated tire is ALSO a Z rated tire and some makers mark the tires with both letters.
I know, it's confusing.......
damon@tirerack.com
877-522-8473 ext. 4643
574-287-2345 ext. 4643
Or use this link:
Old Jul 20, 2005 | 02:31 PM
limitup's Avatar
Yup, it all makes sense now. Thanks. I just ordered one from ya. These are actually 98Y BTW, not 93 ...
danyoP4S
Sep 30, 2021 05:06 AM
WheelB
991 Turbo Vendor Classifieds
Jul 23, 2018 09:37 PM
oo7
Sep 10, 2015 08:08 AM
WheelB
Sep 3, 2015 10:26 AM
gabe325
911
Sep 2, 2015 08:10 PM
