Need Help... (Tech question)
Old Jul 21, 2005 | 12:56 PM
luting_chen's Avatar
luting_chen is infamous around these parts
Hi guys,
I don't know why, but my car is not willing to take any gas
I tried to add gas to it, and I know the tank is empty...
but it just kept on spilling over... and I had to feed it little by little... untill the tank is full...
Todd or Stephen...
do you guys know where went wrong?
I assume it's not related to the fuel injection system I did is it? b/c the car was running fine...
or any parts might got loosen up?
Old Jul 21, 2005 | 01:01 PM
RT7's Avatar
RT7
Show-N-Go like J-Lo Mofo
RT7 is infamous around these parts
It might be that particular gas station, have you tried other places? I believe there's a sensor on the nozzle. I had a similar problem when I was in Phoenix on that particular gas station. I end up holding the nozzle at a certain way.
Old Jul 21, 2005 | 01:03 PM
sharkster's Avatar
Re: Need Help... (Tech question)
Originally posted by luting_chen
Hi guys,
Todd or Stephen...
Man I have that same problem when it comes to sex. Just won't go in. I try to add gas to the tank but it keeps spilling over.
But seriously is this just at one pump or all the time?
Old Jul 21, 2005 | 01:11 PM
Brian Haske's Avatar
Brian Haske is infamous around these partsBrian Haske is infamous around these parts
I'd be willing to bet the fuel pump came loose from the bottom of the fuel tank, etc.
Something obviously came loose/broke
'03 turbo..
call 800porsche and have em tow it into the dealer,
its under warranty
Old Jul 21, 2005 | 01:15 PM
sharkster's Avatar
'03 turbo..
its under warranty
So you're saying I can tell my wife my parts are covered under warranty then eh?
Old Jul 21, 2005 | 01:33 PM
collin996tt's Avatar
Senior Member
collin996tt is infamous around these parts
Did Joan buy the extended warranty? I bet she didn't. Oh well, she can always trade you in.
certified preowned Sharkster
Old Jul 21, 2005 | 01:35 PM
sharkster's Avatar
Well the dealer really jerked her around and remember, she was buying used parts- never tracked or drag raced but much abused anyways. I didn't even have regular oil changes
Old Jul 21, 2005 | 08:32 PM
hahaha... yeah i actually tried different pumps... and different gas station ^_^
didn't work...
have to send it in to dealer to have it checked...
Old Jul 21, 2005 | 08:50 PM
sharkster's Avatar
didn't work...
Sorry Kevin, I was trying to be serious but it's hard sometimes
I hope it checks out ok.. I think Brian hit the nail on the head tho...
Old Jul 21, 2005 | 08:53 PM
jamie's Avatar
This same thing happened to me once at the only gas station by my house that has 94. It only happened once, then the problem disappeared.
Old Jul 21, 2005 | 09:28 PM
KPV's Avatar
KPV
There is a solenoid switch at the gas tank neck. You can hear it activate if you take off the gas cap and press the moveable metal flap with a screwdriver. If you push the metal door open, and move it slightly one way or the other, you will hear the solenoid clicking. I am not sure what this does but undoubtedly it is emissions related.
I have experienced this problem if I am trying to put race gas into the tank with certain types of gas cans. I find that if I stick the screwdriver in the hole and hold it at a particular angle, it will accept the gas from a can. You might try this at the gas station along with holding back the rubber bootie on the pump.
My cursory nderstanding is that it relates to the volatile vapor recovery measures that the car and pump have to employ to comply with US emissions standards.
I have found the symptoms to be sporadic and relatively rare.
Old Jul 21, 2005 | 09:31 PM
KPV's Avatar
KPV
Oh, I nearly forgot. As best as I can tell, the point of the solenoid is to close off a valve at the tank so that the gas is only allowed to fill up the neck. Once you remove the pump, the metal door closes, it senses a closed system and will allow the accumulated gas in the neck to drain into the tank.
Reinsert the pump and you can fill up the neck again.
Old Jul 21, 2005 | 10:04 PM
ebaker's Avatar
ebaker is infamous around these parts
The valve prevents fuel leaking in a rollover.
Old Jul 22, 2005 | 02:14 PM
KPV's Avatar
KPV
Thanks E!!
I learned something new.
