03 99tt
Old Apr 8, 2013 | 12:04 PM
acmf74's Avatar
acmf74 is infamous around these parts
03 99tt
Hi..
I'm looking at a 03 996TT with low mileage (25,XXX) on the clock.
Does this year suffer from the 2nd gear pop-out?
Hopefully this will be my first P-car...
Old Apr 8, 2013 | 12:36 PM
WOODTSTER's Avatar
They all do (996TT 2001-2005) Must drive to insure it doesnt do it.
Old Apr 8, 2013 | 03:26 PM
acmf74's Avatar
Would it pop out under normal driving conditions or under load?
Old Apr 8, 2013 | 04:29 PM
nick49's Avatar
nick49 Is a GOD !nick49 Is a GOD !nick49 Is a GOD !nick49 Is a GOD !nick49 Is a GOD !nick49 Is a GOD !nick49 Is a GOD !nick49 Is a GOD !nick49 Is a GOD !nick49 Is a GOD !nick49 Is a GOD !
It's my understanding that the pop out will occur if accelerating to a fairly high rpm in 2nd and quickly take your foot off the gas. Under decel the car will pop into neutral. Or during a downshift into 2nd when letting out the clutch it will pop into neutral. It won't do it every time, but once it has happened, it will do it more and more. Even once is too many times and will indicate excessive wear.
I researched this quite a bit before buying my Turbo. I concluded that quick aggressive shifting contributes to this excessive wear on the dogs/syncros and leads to this type of failure. Because of this I chose a low mile car that was stock and one where I was certain the owner was not a hot rodder.
I myself am known to be at times a very aggressive driver, but I also know transmissions, mod them and rebuild them. I understand shifting and can feel that 2nd gear needs to be selected rather slow, positive and deliberate compared to the other gears. It takes a moment for spinning gears to slow and match rpms with adjacent gears before finalizing the shift. If you can feel this and shift accordingly, you'll never have a problem no matter how many miles you drive.
I-Man
Sep 2, 2015 02:06 PM
Camo_cab
May 6, 2011 12:20 AM
boca996tt
Aug 8, 2010 08:27 PM
Mad Ness
Feb 4, 2010 01:35 PM
Powell
Oct 21, 2009 02:37 PM
