Donuts in AWD?
Old Jul 24, 2005 | 08:40 PM
StephenTi's Avatar
StephenTi is infamous around these parts
Originally posted by Kraftwerk
Just don't try them in reverse, worst idea I've ever had. You'll end up with this...blown reverse gear tranny taking up space in the garage. Oh well, learning experience, right?
LOL!! Reminded me of a time when a buddy of mine wanted to see how a rear-engined car would accelerate like... with no access to a Porsche, he launced his Eclipse GS-T backwards... took off like a bat outta hell! Top speed was a little limiting though...
Old Jul 25, 2005 | 12:42 PM
Kraftwerk's Avatar
3.6TT/2 = 1.8T
Kraftwerk is infamous around these partsKraftwerk is infamous around these parts
Haha, what the hell, I guess that's a good idea probably not much like a P-car though. I hope he didn't blow anything, it's such a bad feeling. I had seen reverse AWD donuts in a video and didn't think anything of it since I thought it would be just like 1st gear. Well it's not but the reverse ones look even better than forward donuts, for the short while that they lasted.
Old Aug 1, 2005 | 03:48 PM
Turbo Fanatic's Avatar
OK. I've done some research and something doesn't compute. The 996 is designed to send up to 40% torque to the front wheels when the rears are spinning.
That means that the front tires would get the MOST torque when doing donuts. What gives? That's the exact opposite of what we're seeing? Is the AWD slipping during a donut? That would seem pretty abusive of the mechanism.
Old Aug 1, 2005 | 11:21 PM
ebaker's Avatar
ebaker is infamous around these parts
The fluid coupling does slip a lot. It only applies torque to the front when the front and rear axles are turning at a different speeds. From the shop manual, when the rear wheels spin 5 km/hr faster you only get about 200 pounds of forward force from the front axle. You can see from Pierre's video that the front wheels barely spin even on snow.
Old Aug 1, 2005 | 11:38 PM
Mike T's Avatar
Mike T is infamous around these parts
I've managed to do donuts in my 4WD Jeep Grand Cherokee. It's not that hard.
Old Aug 2, 2005 | 01:38 AM
eshaun's Avatar
eshaun is infamous around these partseshaun is infamous around these parts
With the adjustable center diff you can really understand how moving the power back (up to 65/35 i believe in the STi) affects where the axis of rotation is (directly the down center of the car, or closer to the front wheels) and how much power it requires to keep it up smoothly at different speeds.
If you don't mind getting dirty, just do it in the smoothest dirt or gravel lot you can find which is much nicer on your drivetrain and tires
STi tornado
Old Jan 29, 2018 | 11:39 AM
HotRodGuy's Avatar
Originally Posted by My87Targa
slowly drive turning the wheel (at like 5 mph) then ev up pop the clutch and keep wheel turned. i dunno its really not that hard, im sure if you turned your wheel and just punched it, the wheels would all break loose in a matter of seconds.
shouldn't even need to pop the clutch. My car would do them stock by just turning the wheel and hitting the throttle. Does it very easily with a tune.
My kids wanted donuts on sunday for breakfast........so we did donuts
Old Jan 30, 2018 | 08:28 AM
ghostofpain's Avatar
ghostofpain is a splendid one to beholdghostofpain is a splendid one to beholdghostofpain is a splendid one to beholdghostofpain is a splendid one to beholdghostofpain is a splendid one to beholdghostofpain is a splendid one to beholdghostofpain is a splendid one to behold
I guess the PSM was off.
Old Jan 30, 2018 | 11:31 AM
Third-Reef's Avatar
Third-Reef has a reputation beyond reputeThird-Reef has a reputation beyond reputeThird-Reef has a reputation beyond reputeThird-Reef has a reputation beyond reputeThird-Reef has a reputation beyond reputeThird-Reef has a reputation beyond reputeThird-Reef has a reputation beyond reputeThird-Reef has a reputation beyond reputeThird-Reef has a reputation beyond reputeThird-Reef has a reputation beyond reputeThird-Reef has a reputation beyond repute
The "can supply up to 40% of the torque to the front" is deceiving. In certain cases this may be true. Like when the available traction on the rears is low and as the rears spin the viscous coupling firms up and transfers some to the front wheels. This why the car is so stable in the rain. However if you light up the rears on dry pavement i would guess that there is less than 10% going to the fronts as that is all the viscous coupling is capable of. It never locks, by design it cannot. It will barely spin the fronts in the snow if at all. This lack of froward torque transfer is what makes the car still handle like a RWD car and not an AUDI or Subaru.
Old Jan 30, 2018 | 01:21 PM
Stebo's Avatar
Stebo has a reputation beyond reputeStebo has a reputation beyond reputeStebo has a reputation beyond reputeStebo has a reputation beyond reputeStebo has a reputation beyond reputeStebo has a reputation beyond reputeStebo has a reputation beyond reputeStebo has a reputation beyond reputeStebo has a reputation beyond reputeStebo has a reputation beyond reputeStebo has a reputation beyond repute
I have definitely tried with PSM unintentionally On, of course it didn't work. The car sticks like glue! I was half impressed, half depressed. I laughed later when I figured out what happened. I so rarely toggle the PSM button that I didn't even think about it in the heat of the moment. Thank goodness I was alone and no one was there to witness or call me out!
It happens to the best of us... I'm just glad I'm not the only one out there doing donuts in this car. Proud of you guys!
Old Jan 30, 2018 | 02:38 PM
HotRodGuy's Avatar
Thumbs up
:thumbsup:
Old Jan 31, 2018 | 11:04 AM
Road King's Avatar
Road King Is a GOD !Road King Is a GOD !Road King Is a GOD !Road King Is a GOD !Road King Is a GOD !Road King Is a GOD !Road King Is a GOD !Road King Is a GOD !Road King Is a GOD !Road King Is a GOD !Road King Is a GOD !
This lack of forward torque transfer is what makes the car still handle like a RWD car and not an AUDI or Subaru.
Having owned two tuned WRX STIs prior to buying a 996 Turbo, I can certainly confirm this.
On the same coastal canyon roads, the cars behave very differently. The Subie's AWD system is very active, and can actually be felt pulling the car out of a corner. A very fun and very easy car to drive fast on tight backroads! Even when going in too hot, simply applying throttle will move power to the front and the car will maintain traction and squirt out of the corner.
In the 996 Turbo on the same bumpy (and sometimes gravelly) backroads, I have never felt any power in the front wheels. The car simply squats down on it's rear and catapults out of the corner. Definitely no 'pulling' sensation like in the Subie. But it sure works well for my driving style on my favorite roads.
Makes sense with so much weight out back. AWD systems are definitely not created equal. And I'm not so sure that I would want a Subie style AWD engagement with the 911, it definitely impacts steering feel/feedback.
I can't speak to wet weather or donuts though.
Old Jan 31, 2018 | 11:39 AM
993GT's Avatar
993GT Is a GOD !993GT Is a GOD !993GT Is a GOD !993GT Is a GOD !993GT Is a GOD !993GT Is a GOD !993GT Is a GOD !993GT Is a GOD !993GT Is a GOD !993GT Is a GOD !993GT Is a GOD !
easier job for rwd/lsd
Old Jan 31, 2018 | 11:40 AM
993GT's Avatar
awd system in 996 are either very strong or near non existent, depends on the VC condition
Old Jan 31, 2018 | 12:05 PM
s65e90's Avatar
s65e90 is infamous around these parts
There's a nice black gt2 on ebay I really want to buy. Prior salvage but who cares. Perfect daily driver IMO.
