Europipe failure causes extended limp mode
Old Apr 17, 2013 | 11:14 AM
landjet's Avatar
Stef, I just found this out yesterday. I never got any codes or CEL. Coil packs were changed before the incident. Never had any backfires.
Old Apr 17, 2013 | 11:15 AM
landjet's Avatar
Originally Posted by unvmy996
Larry, is this shop located in md?
Yes it is, Hanover Md. At Speed Motorsports, 410-712-4290.
Old Apr 17, 2013 | 12:15 PM
996turbo4365's Avatar
996turbo4365 is a name known to all996turbo4365 is a name known to all996turbo4365 is a name known to all996turbo4365 is a name known to all996turbo4365 is a name known to all996turbo4365 is a name known to all
I am located in Vancouver BC and the OBII test will test for readiness on sensors...so if you turn the rear O2 off it will not pass.
Old Apr 17, 2013 | 01:41 PM
landjet's Avatar
Would someone please clarify for me whether the O2 sensors are purely emissions control devices, or do they actually help add to the car's performance?
Old Apr 17, 2013 | 01:56 PM
2muchtime's Avatar
2muchtime has a reputation beyond repute2muchtime has a reputation beyond repute2muchtime has a reputation beyond repute2muchtime has a reputation beyond repute2muchtime has a reputation beyond repute2muchtime has a reputation beyond repute2muchtime has a reputation beyond repute2muchtime has a reputation beyond repute2muchtime has a reputation beyond repute2muchtime has a reputation beyond repute2muchtime has a reputation beyond repute
Originally Posted by stef@europipe
Catalytic convertors can fail due to backfires and the backfires are caused by ignition interruptions.
Stef
Should I be checking soon, I always get backfire popping and gurgling, thought it was all part of the great sound
Old Apr 17, 2013 | 02:01 PM
unvmy996's Avatar
the first ones are necesarry the secondaries are for emmisions i believe
Old Apr 17, 2013 | 09:10 PM
k-ore's Avatar
k-ore Is a GOD !k-ore Is a GOD !k-ore Is a GOD !k-ore Is a GOD !k-ore Is a GOD !k-ore Is a GOD !k-ore Is a GOD !k-ore Is a GOD !k-ore Is a GOD !k-ore Is a GOD !k-ore Is a GOD !
Pre-cat o2's are a/f.
post-cat o2's are wideband.
This is my assumption.
Larry, did the car feel like the exhaust seemed more muffled and the car was like holding back power, when the problems were active? My car doesn't have cats, but my problem seems very similar to yours, here's my thread: https://www.6speedonline.com/forums/...estricted.html
Old Apr 17, 2013 | 09:39 PM
9bells's Avatar
9bells is a jewel in the rough9bells is a jewel in the rough9bells is a jewel in the rough9bells is a jewel in the rough
Really? Wow. That is not good. Hope that never happens here. Seen a ton of AM cat failures on boosted cars. I recommend removing them once going beyond stockish boost, or adding FI. Seen major issues as a result of cat failure.
Old Apr 17, 2013 | 09:58 PM
TTurbRon's Avatar
TTurbRon is a jewel in the roughTTurbRon is a jewel in the roughTTurbRon is a jewel in the roughTTurbRon is a jewel in the rough
I've used At Speed several times and Rich is the man! The guys over there are great and know there stuff. As far as secondary o2's they are just for emissions to make sure cats are working efficiently. My car has been catless a month after I bought it and as long as your flash raises the threshold for your secondary o2's meaning no cel running catless you won't have any problem passing obd 2 emissions tests.(at least in md) I actually went through my first emission test with straight pipes! Larry, glad to hear you got your car squared away finally!
Old Apr 18, 2013 | 03:17 AM
pete95zhn's Avatar
pete95zhn Is a GOD !pete95zhn Is a GOD !pete95zhn Is a GOD !pete95zhn Is a GOD !pete95zhn Is a GOD !pete95zhn Is a GOD !pete95zhn Is a GOD !pete95zhn Is a GOD !pete95zhn Is a GOD !pete95zhn Is a GOD !pete95zhn Is a GOD !
Just the other way around. Pre-cat lambda sensors are WBO2's and required for proper engine operation. Post-cat ones can be deleted as long as the tune has them removed too.
Old Apr 18, 2013 | 06:52 AM
stef@europipe's Avatar
stef@europipe Is a GOD !stef@europipe Is a GOD !stef@europipe Is a GOD !stef@europipe Is a GOD !stef@europipe Is a GOD !stef@europipe Is a GOD !stef@europipe Is a GOD !stef@europipe Is a GOD !stef@europipe Is a GOD !stef@europipe Is a GOD !stef@europipe Is a GOD !
The popping and gurling when you let off the gas is not the backfire I have in mind. It's when you're at full boost, say a 4000 rpm that worn plugs or worn coil packs create ignition interruptions.
Larry, so your mechanic removed the left side cat, what happened with the right side cat?
Old Apr 18, 2013 | 07:08 AM
landjet's Avatar
Same thing.
Old Apr 18, 2013 | 08:35 AM
Gunther's Avatar
Gunther Is a GOD !Gunther Is a GOD !Gunther Is a GOD !Gunther Is a GOD !Gunther Is a GOD !Gunther Is a GOD !Gunther Is a GOD !Gunther Is a GOD !Gunther Is a GOD !Gunther Is a GOD !Gunther Is a GOD !
Larry I'm so happy for you! Looking forward to seeing you at the track or around town
pwdrhound
Sep 13, 2016 10:44 AM
bobolouie
Macan
Sep 11, 2015 09:08 AM
jyupitt1
Sep 10, 2015 08:31 PM
