New turbos and injectors, first engine start
Old Apr 28, 2013 | 11:06 AM
mrmaass's Avatar
mrmaass has a reputation beyond reputemrmaass has a reputation beyond reputemrmaass has a reputation beyond reputemrmaass has a reputation beyond reputemrmaass has a reputation beyond reputemrmaass has a reputation beyond reputemrmaass has a reputation beyond reputemrmaass has a reputation beyond reputemrmaass has a reputation beyond reputemrmaass has a reputation beyond reputemrmaass has a reputation beyond repute
Today I hope to finish what has been a long but relatively fun process of putting in new injectors
, a pair of alpha 28s and 997.2GT2 RS intercoolers. Honestly the injectors were not fun at all but the rest seems much more straightforward. Tonight if all goes well I will be starting the engine for the first time. Since I had to empty the fuel in the filter and lines I am guessing it will take a minute to start. Because the turbos are new and have no oil initially is there any special procedure that should be used to "prime" them with oil, or any other pre start measures I should take?
Old Apr 28, 2013 | 11:09 AM
Dr. Jekyll's Avatar
Dr. Jekyll is a glorious beacon of lightDr. Jekyll is a glorious beacon of lightDr. Jekyll is a glorious beacon of lightDr. Jekyll is a glorious beacon of lightDr. Jekyll is a glorious beacon of light
Pull the fuel pump fuse and crank the engine over a few times. That should be sufficient to prime the oil lines.
Old Apr 28, 2013 | 11:26 AM
johnspeed's Avatar
Great, Enjoy your new rocket.
Old Apr 28, 2013 | 11:35 AM
TurboTodd's Avatar
TurboTodd has a reputation beyond reputeTurboTodd has a reputation beyond reputeTurboTodd has a reputation beyond reputeTurboTodd has a reputation beyond reputeTurboTodd has a reputation beyond reputeTurboTodd has a reputation beyond reputeTurboTodd has a reputation beyond reputeTurboTodd has a reputation beyond reputeTurboTodd has a reputation beyond reputeTurboTodd has a reputation beyond reputeTurboTodd has a reputation beyond repute
Yep .. pull the C4 fuse. Crank over till you see pressure on the gauge.
Let it idle for a minute or so, then shut down and pull the plugs on the turbo drip tanks to make double sure the turbos are getting oil.
You will Love the 28s !!
Your going to need a bigger intake also to feed them.
Old Apr 28, 2013 | 12:48 PM
BiteEmNBeatEm's Avatar
BiteEmNBeatEm has much to be proud ofBiteEmNBeatEm has much to be proud ofBiteEmNBeatEm has much to be proud ofBiteEmNBeatEm has much to be proud ofBiteEmNBeatEm has much to be proud ofBiteEmNBeatEm has much to be proud ofBiteEmNBeatEm has much to be proud ofBiteEmNBeatEm has much to be proud ofBiteEmNBeatEm has much to be proud of
congrats on the upgrades should run pretty nice!!
bty, what size inj. did you go with?
Old Apr 28, 2013 | 11:39 PM
mrmaass's Avatar
72lb.
Unfortunately I never got to finish today. The tial water return lines require an adapter to be inserted into the existing water line right next to the fuel filter and it is not an easy task. That was the last part of the turbo install and I was so close! Oh well tomorrow ill try again.
Old Apr 29, 2013 | 05:40 AM
BUTZI996TT's Avatar
BUTZI996TT is a jewel in the roughBUTZI996TT is a jewel in the roughBUTZI996TT is a jewel in the rough
Awesome, keep us posted. Enjoy the new power!
Old May 1, 2013 | 10:58 AM
mrmaass's Avatar
Finished!
Last night after removing the right intercooler multiple times to sort out a small leak from the oil supply line to the passenger turbo, I finally got it sorted, put it all back together and installed the EPL base flash for this setup which is limited to 1 bar. I took it for a cautious drive just to make sure there weren't any other leaks or issues. Then I got it on the freeway and did a couple pulls through 4th gear to log Data for the tune modifications and IT WAS AMAZING Even with 1 bar it is a beast compared to my stock K16/1bar flash.
One of my favorite things,and something I have not read about...the Alphas sound incredible! When warming up, my wife said the car sounds like a fighter jet now. The turbo whistle is very noticeable now and it is enough to make your hairs stand on end!
I can't imagine how it will perform with the 100 octane file!
Old May 1, 2013 | 11:59 AM
sounds fun. i remember when i did my alphas, injectors etc in a driveway. injectors were def a project the first time. when i was helping my friend the second time around we had both sides injectors out in an hour flat. newfound power is a good feeling.
#TeamAIM
Old May 1, 2013 | 02:19 PM
ttboost's Avatar
Ah..the good ol days...
Old May 1, 2013 | 02:23 PM
TurboTodd's Avatar
Yep .. just wait till you get those suckers at 1.3-1.4 bar on 100
Then you will know what peoples are talk n bout
One word of caution. The car will rev faster than you think. Keep a close eye on the tach.
Old May 1, 2013 | 03:16 PM
johnspeed's Avatar
HI,If I may ask,,What are you running for an exhaust/cats? Thanks
Old May 1, 2013 | 03:50 PM
mrmaass's Avatar
I'm running ebwerks 3" x-pipe with no cats. The sound of the spool when idling in my parking garage at work is just beyond description.
The accompanying MPH that can get you arrested also comes way faster now
Old May 1, 2013 | 05:59 PM
GTRNICK's Avatar
GTRNICK Is a GOD !GTRNICK Is a GOD !GTRNICK Is a GOD !GTRNICK Is a GOD !GTRNICK Is a GOD !GTRNICK Is a GOD !GTRNICK Is a GOD !GTRNICK Is a GOD !GTRNICK Is a GOD !GTRNICK Is a GOD !GTRNICK Is a GOD !
Got to see a vid of this at stand still and giving some gas too
Old May 2, 2013 | 10:41 AM
f1crazydriver's Avatar
f1crazydriver Is a GOD !f1crazydriver Is a GOD !f1crazydriver Is a GOD !f1crazydriver Is a GOD !f1crazydriver Is a GOD !f1crazydriver Is a GOD !f1crazydriver Is a GOD !f1crazydriver Is a GOD !f1crazydriver Is a GOD !f1crazydriver Is a GOD !f1crazydriver Is a GOD !
Mike, I would like to go for a ride sometime ! You know where I work maybe we can do lunch sometime, or Saturday for a drive.
