911tuning X design custom exhaust
Old May 4, 2013 | 05:04 PM
  #31
johnspeed's Avatar
Originally Posted by MARKSKI@911tuning
Perforated are louder, I tested both options as we experimenting.... I prefer the louvered... We also do not use steel wool for packing like most off the shelf mufflers...
Those still flow enough,not that turbulent, not to hinder power I take it..
Old May 4, 2013 | 05:20 PM
  #32
IDk, you tell me... this is full 3" catless on a 997 with A3076...
2001 996TT 3.6L and stock ECU
9.66
seconds @ 147.76 mph 1/4 mile
click to view
Old May 4, 2013 | 05:29 PM
  #33
johnspeed's Avatar
Well Mark, you tell me if those baffles are in that set-up,, But I do know ones without louvers flow better for the same size diameter..
I dont know your extent of your testing ..
Old May 4, 2013 | 06:01 PM
  #34
I give you an option as I have both louvered and perforated SS cores. I prefer louvered and that is what I recommend.
This car has it. Randy's car has it and his is not even a full 3".
Old May 4, 2013 | 09:54 PM
  #35
machinegunt's Avatar
machinegunt Is a GOD !machinegunt Is a GOD !machinegunt Is a GOD !machinegunt Is a GOD !machinegunt Is a GOD !machinegunt Is a GOD !machinegunt Is a GOD !machinegunt Is a GOD !machinegunt Is a GOD !machinegunt Is a GOD !machinegunt Is a GOD !
Originally Posted by 32krazy!
looks like a great setup. love the tips! what would something like this cost if i may inquire?
+1 That looks incredible!!
Old May 5, 2013 | 02:27 AM
  #36
GT996's Avatar
GT996 has a reputation beyond reputeGT996 has a reputation beyond reputeGT996 has a reputation beyond reputeGT996 has a reputation beyond reputeGT996 has a reputation beyond reputeGT996 has a reputation beyond reputeGT996 has a reputation beyond reputeGT996 has a reputation beyond reputeGT996 has a reputation beyond reputeGT996 has a reputation beyond reputeGT996 has a reputation beyond repute
Hi,
before I started the installation, I cleaned up my rear bumper from all the dirt of last years P-Box measurements - those have been my last runs with the car.
I wanted to see how those tips would look like on my bumper, which has a different cut out for the Gemballa tips compared to a standard 996 TT.
This is how it will look like when mounted:
ID:	239296   Click image for larger version
ID:	239297   Click image for larger version
Old May 5, 2013 | 02:41 AM
  #37
GT996's Avatar
A few words regarding the power restrictions:
Every single bend in an exhaust is a restriction. There is only one optimal thing for a turbo car and that is a straight pipe. I wouldn't call that an exhaust. It is just a tube to direct the hot gases away from underneath the car. If that wouldn't be necessary you could just run a trumpet like short piece of pipe with 3" length.
Comparing this exhaust to straight pipes is just not a valid comparison.
Mark used this exhaust (without cat, of course) on his 1250 HP car. If that power is the result of a restrictive exhaust, I would like to have that exhaust - oh wait....
I have it
Andreas
Old May 5, 2013 | 05:51 AM
  #38
winnigt2's Avatar
winnigt2 has a reputation beyond reputewinnigt2 has a reputation beyond reputewinnigt2 has a reputation beyond reputewinnigt2 has a reputation beyond reputewinnigt2 has a reputation beyond reputewinnigt2 has a reputation beyond reputewinnigt2 has a reputation beyond reputewinnigt2 has a reputation beyond reputewinnigt2 has a reputation beyond reputewinnigt2 has a reputation beyond reputewinnigt2 has a reputation beyond repute
say good by to your stock camshafts and the custom muffler systems begin to shine....so a lot of boost against most time closed valves
Old May 6, 2013 | 05:40 AM
  #39
GT996's Avatar
Yesterday I have finished almost all exhaust related work and only the heat shield needs to be mounted.
Of course I started the car, but it was already 9:30 pm and my neighbors have a little child, so I couldn't test as much as I wanted.
A full description with soundfile/video will follow but for nor I want to say that I am extremely happy with my exhaust.
I checked the soundlevel in my car and did that also with my Gemballa exhaust before so that I have a comparison. At idle this new exhaust is 10 dB less loud in the car (66 dB before, 56 dB with 911tuning exhaust). This very promising regarding drone level and I can't wait to drive the car.
Outside it is 3 dB louder at idle than the previous exhaust.
A 10 dB difference means half as loud as before. At idle that is - we will see how it behaves when I drive it.
If you rev the car, this exhaust is crying for more. It will be fun beyond 3500 RPMs, I guess.
Andreas
ID:	239560   Click image for larger version
ID:	239561   Click image for larger version
Old May 6, 2013 | 11:52 AM
  #40
SamboTT@ByDesign's Avatar
Very clean car! and nice camera too
Old May 6, 2013 | 12:08 PM
  #41
GT996's Avatar
Time for a soundcheck:
I have split the video in two parts in order to not have a boring long warmup time in the video.
Startup and warmup phase until to 2 minutes:
Short rev ups to about 2000 rpm, holding it at around 3000 rpm and then short rev ups to around 4000 rpm.
Let me know what you think. I love it.
Best
Andreas
Old May 6, 2013 | 02:33 PM
  #42
RxPorsche's Avatar
RxPorsche has much to be proud ofRxPorsche has much to be proud ofRxPorsche has much to be proud ofRxPorsche has much to be proud ofRxPorsche has much to be proud ofRxPorsche has much to be proud ofRxPorsche has much to be proud ofRxPorsche has much to be proud of
Thumbs up
Awesome exhaust it sound so fine! I want one so bad, enjoy!!!
Old May 6, 2013 | 03:42 PM
  #43
32krazy!'s Avatar
awesome startup sound and idle. i love the looks but just a tad to quiet for me.
Old May 6, 2013 | 11:42 PM
  #44
GT996's Avatar
Thank you guys.
If you want an exhaust and no straight pipes, just take the catless version of this one and probably don't neck down with the tips. That should give you what you want.
The short pulses at 2000-2500 rpm are already at 99 dB loudness. The i-Phone video doesn't catch what this exhaust really sounds like. I will do better soundchecks when the car is on the road again.
Andreas
Old May 7, 2013 | 03:05 AM
  #45
layinback's Avatar
layinback Is a GOD !layinback Is a GOD !layinback Is a GOD !layinback Is a GOD !layinback Is a GOD !layinback Is a GOD !layinback Is a GOD !layinback Is a GOD !layinback Is a GOD !layinback Is a GOD !layinback Is a GOD !
GT996 911tuning exhaust - YouTube
Best
Andreas
That sounds amazing. Absolutely an incredible looking car you have there
my friend!
32Krazy has heard my cat-less version of your exhaust and he loved it.
He said it had a very nice deep grumble at idle and cruising and a mean
*** whine at speed! I am very very happy with my setup from markski
and it sounds like you are too. Enjoy that beautiful machine my man.
