ABS/PSM failure... which sensor
Old May 20, 2013 | 07:37 PM
nyc996x50's Avatar
nyc996x50 is infamous around these parts
I have that dreaded warning light and it goes on everytime I step on the brake; even when the car is on park. I brought it to one shop who hooked it up to a computer and tells me the whole ABS unit has to be replaced ($3600 part). Took it to another shop for a quick look and tells me the code is showing up as "pressure sensor"
From my understanding, there's the whole ABS unit which consists of the hydraulic pump and the module that controls it, an ABS anti-block sensor which is part #5, and four ABS speed sensors at each wheel.
The shop that hooked up my car to the autologic said i needed to replace the whole unit. Another shop hooked up my car to his laptop and got the "pressure sensor" warning. I wonder if durametric would tell me exactly which sensor is faulty.
I took a look underneath the car and found no leaks. The brakes still work.
Old May 20, 2013 | 07:53 PM
wross996TT's Avatar
Perhaps durametric, but you may need PST2 or PIWIS to find the faulty sensor...
Old May 20, 2013 | 08:10 PM
nyc996x50's Avatar
i think i figured it out! i had my brother step on the brake while i looked at the rear brake light. it goes on once and then doesn't light up after stepping on the brake multiple times. please tell me my problem is the brake light switch!
Old May 21, 2013 | 10:44 AM
DNugget991GT3's Avatar
^ bingo. i will try to find you the troubleshooting site i had specifically for this.
one of the possible causes is the brake light switch. thats probably what it is. good luck amigo !
Old May 21, 2013 | 11:29 AM
#9shooter's Avatar
#9shooter has a spectacular aura about#9shooter has a spectacular aura about#9shooter has a spectacular aura about
Just had the same problem it was pressure sensor. Quick easy and cheap fix.
Old May 21, 2013 | 02:06 PM
XLR82XS's Avatar
Yes you are correct - brake switch.
Old May 21, 2013 | 02:49 PM
Fasoole's Avatar
Fasoole has a brilliant futureFasoole has a brilliant futureFasoole has a brilliant futureFasoole has a brilliant futureFasoole has a brilliant futureFasoole has a brilliant futureFasoole has a brilliant futureFasoole has a brilliant futureFasoole has a brilliant futureFasoole has a brilliant futureFasoole has a brilliant future
I had same problem brake switch, it's annoying
vogz
Oct 8, 2015 12:02 PM
freddiemac
Oct 7, 2015 11:05 AM
Frank ( Sunnyside )
Bentley
Oct 3, 2015 11:13 PM
Oscar 987
Sep 29, 2015 04:57 PM
ECS Tuning - VW
Sep 28, 2015 03:19 PM
