996tt turbine pressure dropping
Old May 25, 2013 | 12:32 AM
AngelOfGrief's Avatar
AngelOfGrief is infamous around these parts
Hello.
I am writing this on behalf of a friend, he has a 996tt like myself, but non-X50, 420hp stock.
He bought the car about a year ago and he's been having this problem:
When the car accelerates, at first turbine pressure starts to rise as it should up to about 0.6-0.7, but then it immediately drops to 0.2-0.3 although gas pedal has not been released.
So the car does not accelerate as it should.
At first he had some faulty sensors: oil pressure sensor (oil pressure gauge falling to zero thing, turning on 'check engine' light), he replaced it. He also recently replaced intake pressure sensor (or whatever it's called), turbine bypasses and also the turbine pressure electric valve. Still the same problem. Everyone is clueless. No PIWIS errors.
If turbine pressure valve is forced open (mechanic somehow tweaked it as an experiment), pressure rises way above 1.0 and does not drop and the car accelerates like crazy. )))
So it looks like the ECU is somehow responsible for this... ECU is 100% stock.
Any ideas, please?
p.s. The car was imported from Arab Emirates.
Old May 25, 2013 | 08:03 AM
BlackHorseTurbo's Avatar
BlackHorseTurbo Is a GOD !BlackHorseTurbo Is a GOD !BlackHorseTurbo Is a GOD !BlackHorseTurbo Is a GOD !BlackHorseTurbo Is a GOD !BlackHorseTurbo Is a GOD !BlackHorseTurbo Is a GOD !BlackHorseTurbo Is a GOD !BlackHorseTurbo Is a GOD !BlackHorseTurbo Is a GOD !BlackHorseTurbo Is a GOD !
Try a boost leak test.
Old May 25, 2013 | 10:04 AM
winnigt2's Avatar
winnigt2 has a reputation beyond reputewinnigt2 has a reputation beyond reputewinnigt2 has a reputation beyond reputewinnigt2 has a reputation beyond reputewinnigt2 has a reputation beyond reputewinnigt2 has a reputation beyond reputewinnigt2 has a reputation beyond reputewinnigt2 has a reputation beyond reputewinnigt2 has a reputation beyond reputewinnigt2 has a reputation beyond reputewinnigt2 has a reputation beyond repute
if the n75 is disconnected from the motronic you have baseboost around 0,3 bar...maybe the electrical circuit is open to the n75 valve...but in this case your have a clear failure code in the motronic
check failure codes motronic and do a leak test...
Old May 25, 2013 | 02:28 PM
There are no failure codes in the ECU. If the valve is blocked, the pressure goes up and does not drop, which clearly means there are no leaks. It's the ECU that opens the bypass valve once the pressure goes up.
Old May 25, 2013 | 04:10 PM
So you're not willing to test for leaks?
Old May 25, 2013 | 06:05 PM
4080's Avatar
4080 has much to be proud of4080 has much to be proud of4080 has much to be proud of4080 has much to be proud of4080 has much to be proud of4080 has much to be proud of4080 has much to be proud of4080 has much to be proud of4080 has much to be proud of
Could be a bad BV. +1 for a boost leak test
Old May 25, 2013 | 07:48 PM
4080's Avatar
Old May 25, 2013 | 11:56 PM
could be a bad DV etc...
but you need to check the turbos.. make sure they are not damaged... then make sure the Wgs open up correctly ... and finally a pressure test...
all this can be done in 2 hours with less then $100 in parts...
2001 996TT 3.6L and stock ECU
9.66
seconds @ 147.76 mph 1/4 mile
click to view
Old May 26, 2013 | 09:13 AM
landjet's Avatar
Also could be a CAT has come out of it's seat and is blocking the exhaust. It happened to me and caused varying boost pressure problems. You have to take the muffler off to see it.
Old May 26, 2013 | 11:46 AM
Thank you for comments, everyone, I'll post an update once we locate the problem. Thanks again.
Old May 27, 2013 | 12:20 AM
What are the empty images that you included in your post? These:
Looks like this person is using the forum for SEO.
Old May 28, 2013 | 02:59 AM
bbywu's Avatar
Spam...thanks for reporting it.
Compukidd
Sep 11, 2015 07:56 AM
Nikg
Sep 10, 2015 09:10 PM
sparks
Sep 8, 2015 03:03 PM
Zmydust
Sep 7, 2015 01:43 PM
petron5000
Sep 6, 2015 11:20 AM
