Anyone have any experience with this clutch?
Old Jun 3, 2013 | 02:24 PM
Steve Jarvis's Avatar
Steve Jarvis Is a GOD !Steve Jarvis Is a GOD !Steve Jarvis Is a GOD !Steve Jarvis Is a GOD !Steve Jarvis Is a GOD !Steve Jarvis Is a GOD !Steve Jarvis Is a GOD !Steve Jarvis Is a GOD !Steve Jarvis Is a GOD !Steve Jarvis Is a GOD !Steve Jarvis Is a GOD !
ACT Xtreme Clutch Kit (Street)
Torque Capacity: 787 ft/lbs
Clamp Load Increase: 37%-88%
All ACT Pressure Plates and discs for the Porsche 911 Pull Type applications are SFI spec 1.1 certified
I did a search, but didn't see any comments from someone using this specific clutch.
Thanks, Steve
Old Jun 3, 2013 | 03:28 PM
King James's Avatar
King James has a reputation beyond reputeKing James has a reputation beyond reputeKing James has a reputation beyond reputeKing James has a reputation beyond reputeKing James has a reputation beyond reputeKing James has a reputation beyond reputeKing James has a reputation beyond reputeKing James has a reputation beyond reputeKing James has a reputation beyond reputeKing James has a reputation beyond reputeKing James has a reputation beyond repute
I was sponsored by ACT in my Talon for a few years when I raced hardcore. They are awesome clutches and held lots of power. Never had a failure and engagement was always really nice. Talon was 500hp (6 years ago that was a lot ) and AWD. I was always able to launch with low 1.7 60fts using a power slip launch method.
No direct experience with that particular clutch on Porsche however.
Old Jun 3, 2013 | 05:04 PM
homwerk's Avatar
homwerk has a spectacular aura abouthomwerk has a spectacular aura about
I am interested in this clutch as well. What other clutches have you used already, Steve?
Old Jun 3, 2013 | 05:33 PM
I'm still on the stock clutch, but it won't hold a launch or quick shift to 4th at my power level.
Later, Steve
Old Jun 3, 2013 | 06:23 PM
homwerk's Avatar
Later, Steve
I am also on the stock clutch but mine is slipping pretty bad in all gears. I have a few quotes on clutches but am unsure on which route to go. I have used ACT many times in the past with zero issues so it's familiar. Also the price is attractive too!
Old Jun 3, 2013 | 06:28 PM
Engine Guy's Avatar
Engine Guy Is a GOD !Engine Guy Is a GOD !Engine Guy Is a GOD !Engine Guy Is a GOD !Engine Guy Is a GOD !Engine Guy Is a GOD !Engine Guy Is a GOD !Engine Guy Is a GOD !Engine Guy Is a GOD !Engine Guy Is a GOD !Engine Guy Is a GOD !
I had one in my car. I hated it with a passion and so did everyone else who drove my car. It was like a light switch and it had about 1/8 of an inch pedal movement between on or off. It only went about 3000 miles in my car before it was baked.
Old Jun 3, 2013 | 06:32 PM
homwerk's Avatar
Ouch! Did you have the street version listed above? Also, if you don't mind sharing, what clutch did you switch to and how do you like it?
Old Jun 3, 2013 | 08:07 PM
Definitely sounds like the race version instead of the street version.
Old Jun 4, 2013 | 06:16 PM
Engine Guy's Avatar
Not 100% sure the exact model designation but it is the one with the full round fiber; I do believe that was the extreme street version. It was paired with a light weight flywheel. It did not work nicely at all.
I went with a ERP as talked about in numerous other threads. It is paired with a GT2 slave conversion and the set up is brilliant. Cary from ERP stands behind his product 100%.
Old Jun 4, 2013 | 06:55 PM
johnspeed's Avatar
Most aftermarket High clamping load pressure plates are modified Sachs units which cause that light switch modulation.
Thats how my last 2 Clutch Masters were but the current one I have from Sachs Performance is perfect a very nice modulation..
Good Luck.
Old Jun 5, 2013 | 08:25 AM
Fallbangskid's Avatar
Fallbangskid has much to be proud ofFallbangskid has much to be proud ofFallbangskid has much to be proud ofFallbangskid has much to be proud ofFallbangskid has much to be proud ofFallbangskid has much to be proud ofFallbangskid has much to be proud ofFallbangskid has much to be proud of
I am running 550+ HP and went through a stock clutch in about 2500 miles.
I wanted a stock, daily driver like clutch that would handle what I have now, and maybe a little more.
I went with a Sachs stage 3 set up and new accumulator from SamboTT and couldn't be happier. Hind site being 20/20, I would start with a new Flywheel of your choice. I went an OEM DMFW.
It is super easy to modulate and great in traffic and stop and go....
Mine feels like stock, but will "light em up" if I need to in order to ward off a pesky wabbit or Corvette....
FBS
Old Jun 5, 2013 | 08:33 AM
johnspeed's Avatar
FBS
What disc did Sam set you up with?
Old Jun 5, 2013 | 08:44 AM
I'm 90+% sure it's the Sachs stage 3. I'd PM him on that as 100% sure would be better. IMO, It is Def a good street/race package with a 60/40% bias to street. I'm pretty easy on clutches if its done right. Sam is a trustworthy guy and will get you very competitive pricing. Likely has it in stock.
FBS
Old Jun 5, 2013 | 09:07 AM
johnspeed's Avatar
FBS
That sounds like the set-up I run and am happy with it over my other precious Clutch Masters set-ups..
Old Jun 5, 2013 | 10:50 AM
Engine Guy's Avatar
If you have used several others it does not sound like they last to long???
