Track day at HPR....
Old Aug 15, 2013 | 11:20 AM
vr4henry's Avatar
vr4henry Is a GOD !vr4henry Is a GOD !vr4henry Is a GOD !vr4henry Is a GOD !vr4henry Is a GOD !vr4henry Is a GOD !vr4henry Is a GOD !vr4henry Is a GOD !vr4henry Is a GOD !vr4henry Is a GOD !vr4henry Is a GOD !
Nice. I was actually planning to get some adjustable rear LCAs so we can tune camber better. My rear passenger side refuses to go past -2.
I'll add the monoballs and castor bits when I do it as well.
Do you have monoballs all around? (front) I wonder about not replacing all the rubber at once.
Old Aug 15, 2013 | 11:46 AM
pwdrhound's Avatar
That's interesting. I have -2.3 camber in the rear and have plenty of more left in the eccentrics, maybe another -0.5 or so. I have the same arms in the rear as the GT2. In the front I have the split GT3 arms and 10mm of shims per side to get -2.7 camber.
I have a JRZ suspension which has monoballs on the front and rear upper mounts, rear lower shock mount, rear LCA and solid rear caster pucks. I was told the front GT3 LCAs have pretty stiff factory bushings and are not that critical. I will change them out when I do the Cup car front uprights next month along with slightly stiffer 700F/900R springs.
Jul 29, 2019 11:13 AM
jyupitt1
Sep 23, 2015 06:26 AM
mikespeed95
Sep 14, 2015 09:48 AM
mjacobellis
Aug 20, 2015 09:13 AM
pwdrhound
Aug 20, 2015 05:54 AM
