Trying to decide between KW V1's and V3's.
Old Jun 22, 2013 | 03:12 PM
sinKing's Avatar
sinKing Is a GOD !sinKing Is a GOD !sinKing Is a GOD !sinKing Is a GOD !sinKing Is a GOD !sinKing Is a GOD !sinKing Is a GOD !sinKing Is a GOD !sinKing Is a GOD !sinKing Is a GOD !sinKing Is a GOD !
What I use the car for: Weekend only, no track work (or if I do it will only be a couple times so this isn't a priority), Driven hard on windy roads (not 10/10ths hard because they are public roads but decently hard). The roads here aren't too bad. Not much in the way of potholes... just some uneven surfaces or bumps - nothing major.
I'm not doing this for appearance purposes, I just want an awesome handling car. Something less GT (as in grand touring not GT2/3) car that handles well and more track car for the street. I don't want something so firm that when I hit a bump going around a turn I lose appropriate contact with the road but definitely firmer than stock.
So, I've narrowed down that if I am going to buy these new I am going with KW. From what I understand the V1's are the same as the V3 but they are preset at the recommended settings for the V3's. No shock adjustability on the V1's. So both are going to be good setups. However, if I get the V3's and just leave them at the recommended settings then I basically paid a $1,400 premium for something I will never use. On the flip side if I get the V1's and am disappointed in some way I will be kicking myself for not getting the V3's in the first place.
This will obviously be a difficult one for someone to truly answer unless they've driven on both.
Other parts on my car: Eibach adjustable sway bars front and rear and Michelin Pilot Super Sports.
Thanks for any input.
Old Jun 22, 2013 | 06:03 PM
viprklr's Avatar
viprklr has a reputation beyond reputeviprklr has a reputation beyond reputeviprklr has a reputation beyond reputeviprklr has a reputation beyond reputeviprklr has a reputation beyond reputeviprklr has a reputation beyond reputeviprklr has a reputation beyond reputeviprklr has a reputation beyond reputeviprklr has a reputation beyond reputeviprklr has a reputation beyond reputeviprklr has a reputation beyond repute
Kw variant
I would go with the KW3. Yoy will have the ability to alter/change the set up if you like. I went with the KW3 & had my tuner /shop go with an aggressive set up & gradually worked backwards. Good luck!!!
Todd
Old Jun 22, 2013 | 06:28 PM
Kendall993's Avatar
Kendall993 is a splendid one to beholdKendall993 is a splendid one to beholdKendall993 is a splendid one to beholdKendall993 is a splendid one to beholdKendall993 is a splendid one to beholdKendall993 is a splendid one to beholdKendall993 is a splendid one to beholdKendall993 is a splendid one to behold
Most guys that I know that don't track their car go with the suggested setting for your car and driving style and then never make another adjustment. Adjustability is nice but very few street cars use it. Either way you will have a nice setup. Good luck.
Old Jun 22, 2013 | 07:57 PM
sinKing's Avatar
Are the types that you know that haven't deviated from the standard settings doing it for appearance and a nice ride or are they still driving it pretty hard on the street, just not 10/10ths on the track and tuning for particular tracks?
Old Jun 23, 2013 | 02:09 PM
Bobbyfali's Avatar
Bobbyfali Is a GOD !Bobbyfali Is a GOD !Bobbyfali Is a GOD !Bobbyfali Is a GOD !Bobbyfali Is a GOD !Bobbyfali Is a GOD !Bobbyfali Is a GOD !Bobbyfali Is a GOD !Bobbyfali Is a GOD !Bobbyfali Is a GOD !Bobbyfali Is a GOD !
My thoughts on the V3.
https://www.6speedonline.com/forums/...pressions.html
My uncle got the PSS9"s with the same suppqrting mods other then my sways and it is a big difference, with the V3 "s feeling much surperior!
Hope that helps .
Old Jun 23, 2013 | 03:32 PM
sinKing's Avatar
Hope that helps .
So what settings do you have them on? Did you stick to the recommended settings or did you fine tune it? Are the roads you're driving on straight or twisty?
Old Jun 23, 2013 | 03:53 PM
pwdrhound's Avatar
I would highly highly recommend the JRZ RS1 set up. It's single adjustable (read simple), you pick your desired spring rates, and the monotube shocks are vastly superior to kw or bilsteins. It comes with monoball uppers. Price is only slightly more than the KW V3s...might be a little more than what you need for a street set up. For a street coilovers the H&R non adjustable kit is fantastic and the valving is spot on for street / mild track use. Bolt on and forget about it for about $2k.. I ran this set up for several years and loved it.
Old Jun 23, 2013 | 04:16 PM
Kendall993's Avatar
A little bit of both. Most of the guys I know drive pretty hard on the street and may track their cars a couple times a year. They usually dont change settings at all.
Old Jun 23, 2013 | 05:06 PM
uschoice's Avatar
uschoice has a brilliant futureuschoice has a brilliant futureuschoice has a brilliant futureuschoice has a brilliant futureuschoice has a brilliant futureuschoice has a brilliant futureuschoice has a brilliant futureuschoice has a brilliant futureuschoice has a brilliant futureuschoice has a brilliant futureuschoice has a brilliant future
Hound- how do you compare the stock set up to the H&R set? Did the H&R's change the ride height too?
Old Jun 23, 2013 | 05:36 PM
pwdrhound's Avatar
My Rturbo came with the RUF PSS9 based kit which was changed over to the H&R coilovers. I have no experience with the stock turbo suspension. I really liked the H&R set up, the valving was spot on. I had the H&Rs replaced with a JRZ track suspension and sold the H&Rs to another TT owner who is very happy with it for a mixed use of street, autocross and track. The only draw back for some with the H&R kit is the fact that you can not get the car much higher than GT2 ride height. GT2 ride height is where your car with end up when the H&Rs are set up at the proper height as spelled out in the installation instructions. The H&Rs will have your car lower than a comparable PSS10 kit.
Old Jun 27, 2013 | 10:38 AM
sinKing's Avatar
I decided on the V3's and ordered them from Vivid today. I can't wait to try them out.
Old Jun 27, 2013 | 10:49 AM
Bobbyfali's Avatar
You would absolutely not regret your decision!! Just make sure you have them set up properly and you would wonder how you enjoyed the car with out them!!
Old Jun 27, 2013 | 04:19 PM
996TWINS's Avatar
996TWINS has a reputation beyond repute996TWINS has a reputation beyond repute996TWINS has a reputation beyond repute996TWINS has a reputation beyond repute996TWINS has a reputation beyond repute996TWINS has a reputation beyond repute996TWINS has a reputation beyond repute996TWINS has a reputation beyond repute996TWINS has a reputation beyond repute996TWINS has a reputation beyond repute996TWINS has a reputation beyond repute
Make sure you trim the front and rear bump stops a bit. My initial installer did not realize how close the top of the coil over is to bump stop, before the travel ran out.
Old Jun 27, 2013 | 05:08 PM
sinKing's Avatar
How much did you lower it? I plan to set mine to the maximum height which is lowering it just under an inch from OE specs.
Old Jun 27, 2013 | 05:50 PM
996TWINS's Avatar
Sorry I do not remember the ride height, now the supplied springs were replaced with higher rates and have less static sag.
But the KW V3s seem to ride (from my experience and what I have read here on the 6 and other forums) inherently low.
For me to say just trim up the bump stops an inch would be easy answer, but may not be the correct one.
What I remember from my initial install, was the shop set the ride height at the halfway point of the total travel of the coil overs, and then corner balanced the car from that point.
Since you bought these from Vivid and they have experience with the KWs, give them a call to get all the information you need to make your installation a success the first time.
Keep us/me posted.
