ring gap
Old Aug 1, 2013 | 08:27 PM
1braincell's Avatar
1braincell is infamous around these parts
ring gap
Does anyone know the specs for the piston ring end gaps and the diameter of the cylinder liner for a 996tt?
Thx
Old Aug 2, 2013 | 05:11 AM
Tim941NYC's Avatar
ID or OD? I use a 100m one piece ring compressor. I run stock gaps on all the rings.
Old Aug 2, 2013 | 08:10 AM
johnspeed's Avatar
Factory ring specs given on most vehicles are usually give looser ,bigger end gap numbers,then what is optimal for a performance stand point..
Usually it is .004 to .005 per inch of bore..
Some school of thought is the 2nd scraper ring should be a little tighter,smaller, then top compression ring and other school of thought is looser,bigger..Both have valid points...
I make mine the same.. LOL..
Old Jan 8, 2017 | 02:27 PM
Warehouse33's Avatar
Warehouse33 is infamous around these parts
Did anybody ever have an answer for the OP? The middle ring land has a dowel in it and I can't find the ring gap. I bought new rings to go on the stock pistons and I can't find any info anywhere. I don't have the old rings to measure to compare.
-Jason
White991TT
Mar 8, 2016 06:01 AM
Sales@RSW
Lamborghini
Oct 1, 2015 02:01 PM
