Last Esprit dyno
Old Aug 10, 2005 | 03:02 AM
allanlambo's Avatar
allanlambo is infamous around these parts
Last Esprit dyno
Finally changed the wastegates, and now the car can hold boost. Only prob is, Lotus matched the turbos on the Esprit so well, the tiny t-25's cant produce more boost. In the end im happy, car runs realy well.
So in really bad conditions, very hot, over 90 deg, with heavy humidity, and no airflow going through, we picked up 10 rwhp, and almost 50ft lbs of torque while running less boost than before.
Old Aug 10, 2005 | 03:25 AM
Dave@EFI's Avatar
Dave@EFI is infamous around these partsDave@EFI is infamous around these parts
Whew! Nice #'s on the Lotus. Congrats Allan!
Old Aug 10, 2005 | 06:24 AM
Turbo Fanatic's Avatar
You're going to want bigger turbis....
Old Aug 10, 2005 | 07:08 AM
RPM's Avatar
RPM
RPM has much to be proud ofRPM has much to be proud ofRPM has much to be proud ofRPM has much to be proud ofRPM has much to be proud ofRPM has much to be proud ofRPM has much to be proud ofRPM has much to be proud of
nice numbers allan. btw, what boost are you putting out right now?
Old Aug 10, 2005 | 07:34 AM
MANA's Avatar
MANA is infamous around these parts
Old Aug 10, 2005 | 07:56 AM
mpwrmodena's Avatar
mpwrmodena is infamous around these parts
Great spool!!!
Old Aug 10, 2005 | 11:55 AM
allanlambo's Avatar
It initially jumps to 12lbs but settles at 11, which is stock.
Old Aug 10, 2005 | 12:47 PM
NAPO's Avatar
NAPO is a splendid one to beholdNAPO is a splendid one to beholdNAPO is a splendid one to beholdNAPO is a splendid one to beholdNAPO is a splendid one to beholdNAPO is a splendid one to behold
Congrats Allan... Those are some nice numbers!
Emre@Esmotor
Oct 19, 2015 12:06 PM
Oct 2, 2015 02:23 PM
ModBargains.com
996 Turbo Vendor Classifieds
Oct 1, 2015 11:48 AM
