cheapest RSS or Wevo mount source
Old May 16, 2016 | 09:21 PM
911-AL's Avatar
911-AL Is a GOD !911-AL Is a GOD !911-AL Is a GOD !911-AL Is a GOD !911-AL Is a GOD !911-AL Is a GOD !911-AL Is a GOD !911-AL Is a GOD !911-AL Is a GOD !911-AL Is a GOD !911-AL Is a GOD !
Reviving this thread. I'm going to keep the Biarritz 996TT and build it and these are first. Looking for the best price on RSS, Wevo or Torque Solutions.
Old May 16, 2016 | 11:38 PM
dynamic gt2's Avatar
dynamic gt2 is a splendid one to beholddynamic gt2 is a splendid one to beholddynamic gt2 is a splendid one to beholddynamic gt2 is a splendid one to beholddynamic gt2 is a splendid one to beholddynamic gt2 is a splendid one to beholddynamic gt2 is a splendid one to behold
Originally Posted by prodigymb
I use Torque Solution mounts and love them. I got the from Mike @AWD, he is a sponsor here and is an awesome vendor to deal with. Chris Green @USP also carries them in stock and just used them in his car that went 9.8 !
is it true that solid mounts cause virtual knock?
Old May 17, 2016 | 07:01 AM
DSCOFF's Avatar
DSCOFF Is a GOD !DSCOFF Is a GOD !DSCOFF Is a GOD !DSCOFF Is a GOD !DSCOFF Is a GOD !DSCOFF Is a GOD !DSCOFF Is a GOD !DSCOFF Is a GOD !DSCOFF Is a GOD !DSCOFF Is a GOD !DSCOFF Is a GOD !
I installed the TS motor and trans mounts back in April, I absolutely love them. It totally transforms the car (no surprise considering that my OEM mounts were shot upon removal).
Considering the age of a lot of these cars, it is something I highly suggest everyone looking into...even if you are just swapping for new OEM parts.
Old May 17, 2016 | 08:35 AM
SeattleTurbo's Avatar
SeattleTurbo Is a GOD !SeattleTurbo Is a GOD !SeattleTurbo Is a GOD !SeattleTurbo Is a GOD !SeattleTurbo Is a GOD !SeattleTurbo Is a GOD !SeattleTurbo Is a GOD !SeattleTurbo Is a GOD !SeattleTurbo Is a GOD !SeattleTurbo Is a GOD !SeattleTurbo Is a GOD !
I have only heard of that happening in a tested scenario on a Boxster. Everything else seems to be hearsay.
I have read they add minimal NVH, if any more, than the the semi solid mount and went for a ride in a local car 996 Turbo with solids and found the NVH to be acceptable level and the owner reported no additional knock or timing changes in his logs.
A benefit of solids that I was told, is they lower the engine in the chassis a small amount compared to others, thereby lowering the center of gravity.
I think that is the route I am going to go, I'll let you know what I find out.
Old May 17, 2016 | 04:17 PM
su_maverick's Avatar
su_maverick Is a GOD !su_maverick Is a GOD !su_maverick Is a GOD !su_maverick Is a GOD !su_maverick Is a GOD !su_maverick Is a GOD !su_maverick Is a GOD !su_maverick Is a GOD !su_maverick Is a GOD !su_maverick Is a GOD !su_maverick Is a GOD !
I will do mine eventually but its a kick in the groin to know that these things went up 50% in the past couple years
Old May 17, 2016 | 06:06 PM
32krazy!'s Avatar
i think ecs tuning has a 25% special going on
Old May 27, 2016 | 05:45 PM
estoril4dr's Avatar
estoril4dr is infamous around these parts
looking to do this as well.
does everyone pretty much do the trans mounts at the same time as well?
Old May 27, 2016 | 08:44 PM
Never Enough's Avatar
Never Enough is a glorious beacon of lightNever Enough is a glorious beacon of lightNever Enough is a glorious beacon of lightNever Enough is a glorious beacon of lightNever Enough is a glorious beacon of lightNever Enough is a glorious beacon of light
I replaced the old 996tt tranny mount with a 997tt mount, and found it was a very nice improvement over the 996tt which I highly recommend. The upgrade provides smoother shifting for sure, and a more stable drive line that improves handling. With only a floor jack and jack stands, that job took about 3 hours but I was taking my time with frequent breaks for a tired old back.
A week later I replaced the hydraulic engine mounts with RSS semi-solid mounts, and that was a very noticeable improvement in driveline stability. That job was certainly a little easier than the tranny mount, and took about 2 hours start to finish.
While my prior opinion about the car's handling was that it was a little vague and unpredictable, I feel that changing the mounts has made the handling much more precise, and I was fairly pleased with the car's handling on the Summit Point main course last weekend.
Although it was raining all weekend and there were many off track adventures with even a few instructors losing control a few times, I found the car's handling to be pretty good in the sloppy conditions.
Jul 29, 2019 11:13 AM
