GT2 clutch conversion went limp, probable cause?
Old Aug 27, 2013 | 08:31 PM
brnrdtns's Avatar
brnrdtns Is a GOD !brnrdtns Is a GOD !brnrdtns Is a GOD !brnrdtns Is a GOD !brnrdtns Is a GOD !brnrdtns Is a GOD !brnrdtns Is a GOD !brnrdtns Is a GOD !brnrdtns Is a GOD !brnrdtns Is a GOD !brnrdtns Is a GOD !
My clutch went soft to the floor. I just put it on stands and took a look at it and there does not appear to be any fluid leaking out. Could the master or the slave cyl have gone out? I'm worried that I may not have gotten all of the pentosin out and it killed the slave.
Old Aug 27, 2013 | 09:33 PM
brnrdtns's Avatar
Reading the the GT2 master are cheap, I'll check mine.
Old Aug 27, 2013 | 11:19 PM
scsponger31's Avatar
scsponger31 is a splendid one to beholdscsponger31 is a splendid one to beholdscsponger31 is a splendid one to beholdscsponger31 is a splendid one to beholdscsponger31 is a splendid one to beholdscsponger31 is a splendid one to beholdscsponger31 is a splendid one to behold
Are you sur there is not any air in the system?
Old Aug 27, 2013 | 11:23 PM
brnrdtns's Avatar
Yah it was bled out and I drove on it for a few months. Looks like it is the master cyl, not pumping fluid through at all and the res stays at the same level. There are a few threads on here that the GT2 master is hit or miss.
Old Aug 28, 2013 | 01:40 PM
uschoice's Avatar
uschoice has a brilliant futureuschoice has a brilliant futureuschoice has a brilliant futureuschoice has a brilliant futureuschoice has a brilliant futureuschoice has a brilliant futureuschoice has a brilliant futureuschoice has a brilliant futureuschoice has a brilliant futureuschoice has a brilliant futureuschoice has a brilliant future
brnrdtns - like Carbon said, check your slave and master cylinders.
I wrote about this last month. My GT2 conversion was only about a year old, but both the slave and master failed. Replaced both and all is good for now. BTW, there doesn't have to be any outward signs of leakage for them to be bad.
Old Aug 28, 2013 | 03:39 PM
brnrdtns's Avatar
Checked the master and it is clearly not working as before. I'll assume that the slave is OK for now, only 1,000 miles on the new setup!
Old Aug 29, 2013 | 09:44 PM
Mad Ness's Avatar
Mad Ness has a brilliant futureMad Ness has a brilliant futureMad Ness has a brilliant futureMad Ness has a brilliant futureMad Ness has a brilliant futureMad Ness has a brilliant futureMad Ness has a brilliant futureMad Ness has a brilliant futureMad Ness has a brilliant futureMad Ness has a brilliant futureMad Ness has a brilliant future
if the original fluid wasn't properly drained, the residuals will cause the slave or master (can't remember which it was happened couple years ago) to fail over time. That happened to me, drove fine for a while before it went out.
Old Sep 3, 2013 | 10:48 AM
XLR82XS's Avatar
Gotta make sure ALL of that Pentosin is gone. It will kill the slave.
Old Sep 3, 2013 | 11:42 AM
brnrdtns's Avatar
It was the master cyl. Hopefully my slave cyl holds up.
SharkyShark20
Sep 19, 2015 09:54 PM
cby1
Sep 1, 2015 10:25 AM
irish100p
Aug 31, 2015 01:04 PM
orbelo
Aug 30, 2015 12:26 PM
TrackOne
Aug 20, 2015 12:56 PM
