Key Fob Issue
Old Nov 11, 2013 | 12:55 AM
  #31
Urban's Avatar
Urban has a spectacular aura aboutUrban has a spectacular aura about
Originally Posted by '02996ttx50
a new fob will not remedy failed "guts". ever take a look at that circuit board inside? that they have even lasted 10+ years is the real mystery lol
Well the last few days my car alarm has been going off at all times of the night while parked on the street (GFs place). Not fun at 1am running outside to turn it off by key so I decided to install and aftermarket alarm and disconnect the stock one and now use the new fob that came with the alarm system to open doors and trunk. I just use the stock key to start the car so my problem is solved via a different route.
Old Nov 11, 2013 | 04:42 AM
  #32
'02996ttx50's Avatar
i had that happen also. car alarmed for *no* reason! thought it was something to do with the motion sensor feature but it happened all as the guts were failing. now my spare won't activate the trunk button but still locks/unlocks the car.
my next move is two new 996 fobs w guts and have them programmed by the stealer. that should set me back about 600. it's always the little sh*t.
Old Sep 3, 2014 | 10:57 AM
  #33
atisvt99's Avatar
atisvt99 has a brilliant futureatisvt99 has a brilliant futureatisvt99 has a brilliant futureatisvt99 has a brilliant futureatisvt99 has a brilliant futureatisvt99 has a brilliant futureatisvt99 has a brilliant futureatisvt99 has a brilliant futureatisvt99 has a brilliant futureatisvt99 has a brilliant futureatisvt99 has a brilliant future
Were there ever any updates to this problem? I just had the same failure that some of you all are reporting... Red light on the fob still blinks, but doors and trunk don't respond. My other key fob still works fine (for now)...
thanks
Old Sep 3, 2014 | 12:09 PM
  #34
i ended up getting two new fobs and the programming of both at an indie was 100.
Old Sep 3, 2014 | 12:35 PM
  #35
Steve Jarvis's Avatar
Steve Jarvis Is a GOD !Steve Jarvis Is a GOD !Steve Jarvis Is a GOD !Steve Jarvis Is a GOD !Steve Jarvis Is a GOD !Steve Jarvis Is a GOD !Steve Jarvis Is a GOD !Steve Jarvis Is a GOD !Steve Jarvis Is a GOD !Steve Jarvis Is a GOD !Steve Jarvis Is a GOD !
I purchased a new fob, had it programmed and everything works great again.
Later, Steve
Old Sep 3, 2014 | 12:52 PM
  #36
atisvt99's Avatar
Good to know... thanks, gents!
Steve, did you have yours done at a stealership, or also at a local shop?
Old Sep 3, 2014 | 12:55 PM
  #37
Dealership
Old Sep 4, 2014 | 06:08 AM
  #38
gclasse's Avatar
gclasse has a reputation beyond reputegclasse has a reputation beyond reputegclasse has a reputation beyond reputegclasse has a reputation beyond reputegclasse has a reputation beyond reputegclasse has a reputation beyond reputegclasse has a reputation beyond reputegclasse has a reputation beyond reputegclasse has a reputation beyond reputegclasse has a reputation beyond reputegclasse has a reputation beyond repute
Cant believe it!!! This just happened to me on the past days. I can still use the key to turn the car on, but cant use the transponder to turn on/off the alarm or the frunk!! The other key is working perfectly..
cnebrask
Oct 3, 2024 08:19 PM
Armytrix_F1_Exhaust
Jul 7, 2019 11:31 PM
007AMV8
Oct 19, 2015 09:55 PM
cordsig79
Cayenne 955/957
Aug 28, 2015 12:36 PM
I'mAllIn
Aug 25, 2015 09:44 AM
