What part is this?
Old Oct 20, 2013 | 07:11 AM
NTIMD8's Avatar
NTIMD8 has a reputation beyond reputeNTIMD8 has a reputation beyond reputeNTIMD8 has a reputation beyond reputeNTIMD8 has a reputation beyond reputeNTIMD8 has a reputation beyond reputeNTIMD8 has a reputation beyond reputeNTIMD8 has a reputation beyond reputeNTIMD8 has a reputation beyond reputeNTIMD8 has a reputation beyond reputeNTIMD8 has a reputation beyond reputeNTIMD8 has a reputation beyond repute
What part is this?
Hi guys, doing a boost leak test I noticed the top rubber line making bubbles even at very low pressure. I tried zip tying the hose but no luck. It is almost as if the air is coming from further down within the box. I thought about using some epoxy to seal it but I need to know what this part does and whether or not that is a good idea. Any info from people who know would be appreciated.
It is behind the alternator on the drivers side of the y-pipe. Grey box with a bunch of vac hoses (some of which go to the diverter valves) and an electrical connection at the top.
Thanks!!!
Old Oct 20, 2013 | 08:18 AM
jpflip's Avatar
Electric switch over valve to control the diverter valves (overrun valves). It get his muscle negative pressure from the vacuum chamber and when electric signal comes from the ecu it open to provide vacuum to the diverter valves and open them to bleed intake pressure.......Item #45 on the parts cat and the price is $59.44.
Name:	Capture d’écran 2013-10-20 à 10.16.08.jpeg
ID:	291575   Click image for larger version
Name:	Capture d’écran 2013-10-20 à 10.15.32.jpeg
ID:	291576   Click image for larger version
Name:	Capture d’écran 2013-10-20 à 10.22.32.jpeg
Old Oct 20, 2013 | 09:07 AM
03 996tt's Avatar
03 996tt has a brilliant future03 996tt has a brilliant future03 996tt has a brilliant future03 996tt has a brilliant future03 996tt has a brilliant future03 996tt has a brilliant future03 996tt has a brilliant future03 996tt has a brilliant future03 996tt has a brilliant future03 996tt has a brilliant future03 996tt has a brilliant future
JP to the rescue again. I think this site should be called Tim and JPFlips 6speedonline.
Old Oct 20, 2013 | 09:23 AM
NTIMD8's Avatar
Thanks JP. Rep coming your way.
Old Oct 20, 2013 | 09:25 AM
jpflip's Avatar
... Tim knows a lot more than me about cars!!!! And I am useless with modifications or higher H.P.!!! But If I know the answer I am happy to share ;-)
Old Oct 20, 2013 | 10:00 AM
SamboTT@ByDesign's Avatar
+1 for JP. Always helpful!
Old Oct 20, 2013 | 10:04 AM
jpflip's Avatar
Thanks guys!!!
Old Oct 20, 2013 | 10:06 AM
NTIMD8's Avatar
Cool, so that second picture tells me that since it is the top tube that is bubbling it is the pressure tube and not vacuum which makes perfect sense as to why it would bubble. Also looks like I should be able to just tighten the clamp somehow (a better way than a tiewrap since that didn't work).
PS, I tried to give you rep but it said I have to spread it around before I can do so. SO you obviously helped me before, lol
Old Oct 20, 2013 | 10:23 AM
jpflip's Avatar
It is also a vacuum line. Remember you are doing a pressure test. So pressure gets into the vacuum line since there is no power iapplied to any switches and the pressure comes from the intake assembly.....
Old Oct 20, 2013 | 12:57 PM
NTIMD8's Avatar
Ah yes true. I took the y-pipe off and sealed it so should be good. Found a few minor leaks here and there but nothing major.
Old Oct 20, 2013 | 01:34 PM
jpflip's Avatar
Good job!!! Another happy mechanic...There is a certain feeling of satisfaction when we can repair our car ourselves!!
Old Oct 21, 2013 | 08:24 PM
rangerdick's Avatar
rangerdick has a spectacular aura aboutrangerdick has a spectacular aura aboutrangerdick has a spectacular aura about
I always love the "what is...." post and then see the Jpflip as the most recent answer. I always know my knowledge base will increase significantly when I read JP's response. JP thanks for contributing.
Old Oct 21, 2013 | 09:13 PM
kwei's Avatar
kwei has much to be proud ofkwei has much to be proud ofkwei has much to be proud ofkwei has much to be proud ofkwei has much to be proud ofkwei has much to be proud ofkwei has much to be proud ofkwei has much to be proud of
Yes I have to chime in and give jp props as well. Very helpful member and has chimed in more than once on my own threads.
My answer to the OPs question would have been "bubble blowing line". Is that rep worthy as well? : )
Old Oct 22, 2013 | 12:27 AM
jpflip's Avatar
Thank you very much gentlemen. You encourage me to continue to help those who are in the dark. I love doing it and at the same time I make friends! Plus, we have a common passion, Porsche
Old Oct 22, 2013 | 05:39 AM
'02996ttx50's Avatar
jp! you continue to help even those who are firmly in the light LOL
