Tip differential carrier bearings
Old Oct 23, 2013 | 02:53 PM
1braincell's Avatar
1braincell is infamous around these parts
Hi,
Need to replace the differential bearings and cups from a 996 tt tiptronic transmission and was wondering if anyone can provide the part numbers for both the bearings and cups.
Old Oct 23, 2013 | 04:58 PM
pumptech's Avatar
pumptech has a reputation beyond reputepumptech has a reputation beyond reputepumptech has a reputation beyond reputepumptech has a reputation beyond reputepumptech has a reputation beyond reputepumptech has a reputation beyond reputepumptech has a reputation beyond reputepumptech has a reputation beyond reputepumptech has a reputation beyond reputepumptech has a reputation beyond reputepumptech has a reputation beyond repute
I would guess you are going to have to dig them out and source them. While this is a Mercedes tranny I have never come across the rear differential parts or diagrams. I suspect they may come from older 911's
Old Oct 23, 2013 | 05:22 PM
993GT's Avatar
993GT Is a GOD !993GT Is a GOD !993GT Is a GOD !993GT Is a GOD !993GT Is a GOD !993GT Is a GOD !993GT Is a GOD !993GT Is a GOD !993GT Is a GOD !993GT Is a GOD !993GT Is a GOD !
the bearing part # for a g96/88(GT2 trans) is 999-059-064-00, not sure if same for a Tip(couldn't find diagram or part#)...by cups do you mean the adjustment shims?
Cheers,
Old Dec 2, 2013 | 10:03 PM
1braincell's Avatar
Just wanted to update this thread in case anyone else needs to go down this road. Pulled the differential carrier bearings and ordered replacement parts. For future reference both bearing and cups are from Timken. Part numbers for the outer bearing and cup are LM806649 and LM806610, respectively. Inner bearing and cup are a set pn 32010X. Hope this helps.
The spacer shims - well that's a tough one. Might have to get them custom made.
Old Dec 3, 2013 | 05:31 AM
pat's Avatar
pat
pat has a reputation beyond reputepat has a reputation beyond reputepat has a reputation beyond reputepat has a reputation beyond reputepat has a reputation beyond reputepat has a reputation beyond reputepat has a reputation beyond reputepat has a reputation beyond reputepat has a reputation beyond reputepat has a reputation beyond reputepat has a reputation beyond repute
Good info
jaehoppa
Oct 22, 2015 09:17 PM
nyjetfan
Oct 17, 2015 01:32 PM
BLKMGK
Sep 19, 2015 03:51 PM
cordsig79
Cayenne 955/957
Sep 10, 2015 03:12 PM
