How do I extend rear seat belt?
Old Oct 26, 2013 | 02:31 PM
bk944's Avatar
bk944 is infamous around these parts
Bought a set of used rear seat belts on the internet. Everything looks good but it won't extend. Seems like it's stuck. When I tried to pull on the belt, it extends for 1 inch then stopped. Tried playing with both belts for about half an hour but nothing worked.
Any help will be appreciated. I was so looking forward to taking my son out on the back seat today.
Old Oct 26, 2013 | 09:57 PM
pat's Avatar
pat
pat has a reputation beyond reputepat has a reputation beyond reputepat has a reputation beyond reputepat has a reputation beyond reputepat has a reputation beyond reputepat has a reputation beyond reputepat has a reputation beyond reputepat has a reputation beyond reputepat has a reputation beyond reputepat has a reputation beyond reputepat has a reputation beyond repute
Picture...
Old Oct 26, 2013 | 11:22 PM
machinegunt's Avatar
machinegunt Is a GOD !machinegunt Is a GOD !machinegunt Is a GOD !machinegunt Is a GOD !machinegunt Is a GOD !machinegunt Is a GOD !machinegunt Is a GOD !machinegunt Is a GOD !machinegunt Is a GOD !machinegunt Is a GOD !machinegunt Is a GOD !
I have seen seat belt extenders on the airplanes! How big is your kid?
Old Oct 27, 2013 | 09:51 AM
wross996TT's Avatar
To get the seat belts to actuate they need to be plugged in.
Old Oct 27, 2013 | 12:48 PM
pwdrhound's Avatar
There is no plug on the rear belts as mentioned in a post above. In order for the belts to extend, the mounting surface has to be in a vertical orientation with the seat belt mechanism angled forward about 20 degrees. They will then extend. There is some mechanism in the belt reel that locks it when it senses that the car is under some Gs or not level, as when the car rolling over for example. I just pulled the rear seat belts out of a box in the basement and verified the info above. You have to play with it a little bit but once you get the belts in the proper orientation they will extend. The front belts I believe have an electrical connection to actuate the belt pre-tensioners.
Old Oct 27, 2013 | 06:01 PM
bk944's Avatar
Got it. Thanks Pwdrhound and everyone else. It worked after many tries.
Old Oct 28, 2013 | 11:05 AM
wross996TT's Avatar
Sorry I meant installed...the front ones need to be connected...my bad
cnebrask
Oct 3, 2024 08:19 PM
r_matt_6
Oct 8, 2015 06:07 PM
STAGGERED M3
Sep 11, 2015 12:00 AM
The Oss
Aug 24, 2015 08:19 PM
saline
Aug 19, 2015 12:25 PM
