Engine rebuild questions...
Thanks for the kind words. The motor is currently complete. It is currently a 4.3L (105.7 mm x 82.4 mm)with not a single part that has not been reviewed, redesigned and manufactured. The motor is out of the car and a MOTEC M880 with all options is being fitted as well as a custom designed RAMP front LSD. She made just over 1000 hp @ 1 bar on an engine dyno. She is designed for 2.8 bar. She is also fitted with a progressive 300 shot of nitrous (10 hp shot added every 1/10 of a sec.) Nitrous was not used on the above engine dyno test.
You are correct about grinding the crank and there are two things you can do.
#1 - Grind the crank as a center grind and keep the same stroke.
#2 - Grind the crank as an offset and gain 2 mm of stroke. This was our choice. Our Arrow Precision crank started out as a 80.2 mm stroker from Arrow. We added the Oval bearings and did an offset grind to make it a 82.4 mm stroker. If we were to do it all over again I would have stayed with the 80.4 mm crank and could have obtained a better piston to rod ratio or piston speed. If I was dealing with a billet GT3 crank with a stock 78.4 mm stroke than I would have used the oval bearings and an offset grind to make it a 80.4 mm stroker.
I have priced some custom built cranks and I had a quote to build a pretty sweet billet forged crank for about $1500. The guy said he could do it stronger and lighter than factory. Did you ever consider anything like this?
Are you also saying the Spanish case is better than the 964 Germany case? Iv got one of each and prefer to keep the enter of the 2 for myself.
Spanish case is better as it's made for the watercooler's without provisions for oil return tubes used on the air-cooled's, IIRC some slight structural improvement inside...I doubt it makes much improvement until "perhaps" these 1000+hp mega builds...
The Spanish case has support ribs the other case doesn't. The Spanish case is in fact a stronger case.
Ribs on the Spanish case as well as tap and fitting for GT1 oil pump.
I just looked in a Porsche technical manual and it did say our cylinders are Nikasil coated....As my past water cooled 944 turbos were..
Also all the cylinder sleeves that I have treated our cast iron to begin with..
Just sharing info..
I call BS on the that. The 996 Non Metzger engines use nikasil because the cylinders and castings are aluminum and all one piece. With the Metzger engines the sleeves are steel(alloy) and separate from the water jacket which allows for wear and are replaceable. Why use nikasil? I think that was a typo. Of course I have no proof :/
Nikasil is used when ever long life is needed and when minimal material wear from sleeves is a concern for keeping oil from being contaminated from that sleeve material..
