O ring and not an aluminum crush ring in turbo install
Old Nov 24, 2013 | 01:24 PM
stilov's Avatar
stilov Is a GOD !stilov Is a GOD !stilov Is a GOD !stilov Is a GOD !stilov Is a GOD !stilov Is a GOD !stilov Is a GOD !stilov Is a GOD !stilov Is a GOD !stilov Is a GOD !stilov Is a GOD !
So I am in the middle of a long turbo swap with all sorts of fun problems
So, on to my question. I looked at the diagram
http://www.jimellisporscheparts.com/...rimLevel=18178
And order the #10 sealing rings...well there are rubber o-rings between the oil catch/reservoir and the turbo...
Anyone have a part number?
Old Nov 24, 2013 | 01:29 PM
32krazy!'s Avatar
90012314030
Old Nov 24, 2013 | 02:14 PM
GT996's Avatar
GT996 has a reputation beyond reputeGT996 has a reputation beyond reputeGT996 has a reputation beyond reputeGT996 has a reputation beyond reputeGT996 has a reputation beyond reputeGT996 has a reputation beyond reputeGT996 has a reputation beyond reputeGT996 has a reputation beyond reputeGT996 has a reputation beyond reputeGT996 has a reputation beyond reputeGT996 has a reputation beyond repute
The #10 is the wrong number. The porsche parts catalog image is wrong in that detail.
Old Nov 24, 2013 | 02:24 PM
jpflip's Avatar
Went to look at my stock of parts and this is what I got for 900-123-140-30. This crush washer is good for the turbo reservoir drain plug but I am not sure for the sealing between the turbo and the reservoir. Of course rubber in this location seems strange because of the high heat!
Name:	Capture d’écran 2013-11-24 à 16.23.25.jpeg
ID:	305233   Click image for larger version
Name:	Capture d’écran 2013-11-24 à 16.26.48.jpeg
Old Nov 24, 2013 | 03:40 PM
Tim941NYC's Avatar
Old Nov 24, 2013 | 03:42 PM
Tim941NYC's Avatar
And number 3 on the link you posted is inlet
Old Jan 2, 2014 | 08:50 PM
stilov's Avatar
Just FYI. Turns out the correct part is number 11 on the parts list but there is no #11 in the diagram.
Old Jan 2, 2014 | 08:56 PM
jpflip's Avatar
Good to know, the second 10 should be 11 on the drawing at the drain plug of the reservoir…Thanks!
note, just went to check with the PET and also the latest parts cat from Porsche and the error is still there….
Old Jan 2, 2014 | 11:52 PM
GT996's Avatar
No at the drain plug the #10 ist correct. The above #10 should be #11. You don't want to have an o-ring at the drain plug. Its place is between oil reservoir and turbo flange.
Andreas
Old Jan 3, 2014 | 05:47 AM
jpflip's Avatar
Andreas
Thanks for the correction!
Mackchacha
Jul 9, 2019 11:03 AM
ModBargains
Aug 20, 2015 12:28 PM
Aug 19, 2015 06:35 PM
