Tire time...size question, not brand
Old Nov 25, 2013 | 03:50 PM
stilov's Avatar
stilov Is a GOD !stilov Is a GOD !stilov Is a GOD !stilov Is a GOD !stilov Is a GOD !stilov Is a GOD !stilov Is a GOD !stilov Is a GOD !stilov Is a GOD !stilov Is a GOD !stilov Is a GOD !
So I have 18in champion RG5's (car came with 235/40 on front and 285/35 on rear)
The fronts are 8.5in wide and the rears are 11in wide.
I am needing to buy pretty soon.
Are there recommended sizes for this set-up?
I really feel like the rear needs a hair more width, it's not stretched by any means, but it doesn't have nearly the whee protection the front has.
Old Nov 25, 2013 | 04:14 PM
996TWINS's Avatar
996TWINS has a reputation beyond repute996TWINS has a reputation beyond repute996TWINS has a reputation beyond repute996TWINS has a reputation beyond repute996TWINS has a reputation beyond repute996TWINS has a reputation beyond repute996TWINS has a reputation beyond repute996TWINS has a reputation beyond repute996TWINS has a reputation beyond repute996TWINS has a reputation beyond repute996TWINS has a reputation beyond repute
Factory rears are 295/30 for 18".
Many others here run either 305 or 315 rears. Check the wheel offset for proper fitment.
Old Nov 25, 2013 | 04:18 PM
'02996ttx50's Avatar
you can safely run the 315/30 which'll give ya about .8 inch wider. but you *might* need to roll your fenders. it's well worth it.
stay w the 235/40 front.
Old Nov 25, 2013 | 04:28 PM
johnspeed's Avatar
I ran those sizes for quite a while because I went with all season tires in the winter..But now I run 295/35/18 and 245/40/18 Conti's which do me good ...My car does ride great ,, pot hole protection, I have more front lip clearance and I can change my oil easier...
Old Nov 26, 2013 | 07:14 AM
stilov's Avatar
this is a daily driver if that changes anyones thoughts.
The 305's don't seem to be available.
Old Nov 26, 2013 | 11:52 AM
TXTurbo996's Avatar
TXTurbo996 has much to be proud ofTXTurbo996 has much to be proud ofTXTurbo996 has much to be proud ofTXTurbo996 has much to be proud ofTXTurbo996 has much to be proud ofTXTurbo996 has much to be proud ofTXTurbo996 has much to be proud ofTXTurbo996 has much to be proud ofTXTurbo996 has much to be proud of
I run 315/30's and 235/40 on 18's, 8" in front, 11" in rear, lowered with H&R springs. No rubbing issues.
Old Nov 26, 2013 | 12:23 PM
ard's Avatar
ard
I've run:
295/30-19 w 225/40-18 -stock size, stock rims, stock everything
315/30-18 with 235/40-18 on stock rims, stock suspension. Those are "GT2 stock sizes". no fender rolling
315/30-18 with 265/35-18 9" and 11.5" rims, no fender rolling, Motons, lwoered to Gt2 heights. Slight rub on front at full lock ("hey doc it hurts when I do this. So....")
I am pretty sure there there are no 265/35s that work on an 8.5 rim, so you will be maxed with the 235/40.
All michelin PS2s
Old Nov 26, 2013 | 12:38 PM
johnspeed's Avatar
With stock suspension/height 245/40/18 will work also
COBB Tuning
Jan 1, 2025 09:02 AM
COBB Tuning
Nov 9, 2015 08:02 PM
turbotuner20v
Sep 11, 2015 12:02 PM
Zero911
Aug 24, 2015 06:51 PM
oddjob142
Aug 19, 2015 12:27 PM
