1.4 Bar Tune = 1.5 Bar in Cold Weather?
Old Dec 30, 2013 | 12:01 AM
  #31
Durametric Cable for guys like You are a must.
You log It and see exactly what it's doing. 1st gear usually does not produce full boost. Second gear is closer. 3rd usually is the one. Depends on your turbos and set up too.
Old Dec 30, 2013 | 12:06 AM
  #32
Urban's Avatar
Urban has a spectacular aura aboutUrban has a spectacular aura about
You log It and see exactly what it's doing. 1st gear usually does not produce full boost. Second hear is closer. 3rd usually is the one. Depends on your turbos and set up too.
Thanks that is what I thought but just wanted to confirm boost levels per given gear.
The rest I can take care of once I understand the mods on this car as it looks like the clutch is aftermarket too.
Old Dec 30, 2013 | 08:18 AM
  #33
996tt550hp's Avatar
996tt550hp has a reputation beyond repute996tt550hp has a reputation beyond repute996tt550hp has a reputation beyond repute996tt550hp has a reputation beyond repute996tt550hp has a reputation beyond repute996tt550hp has a reputation beyond repute996tt550hp has a reputation beyond repute996tt550hp has a reputation beyond repute996tt550hp has a reputation beyond repute996tt550hp has a reputation beyond repute996tt550hp has a reputation beyond repute
Originally Posted by Urban
I have an appt. with SharkWerks next month as I need to know what has been done to this car...I know it has a tune for sure.
Thats great bring it to them i was in your shoes but i found a vacuum hose off on the fpr. Your car should be smooth all the way too redline. Again markski is right but in cold weather if your making 1.3 bars and its going to 1.5 bars something is not right no matter how cold it is. Right now i am at 1.1 bars and i see 1.1 bars still at 38 degrees.
Old Dec 30, 2013 | 09:27 AM
  #34
Wealth Manager's Avatar
Wealth Manager Is a GOD !Wealth Manager Is a GOD !Wealth Manager Is a GOD !Wealth Manager Is a GOD !Wealth Manager Is a GOD !Wealth Manager Is a GOD !Wealth Manager Is a GOD !Wealth Manager Is a GOD !Wealth Manager Is a GOD !Wealth Manager Is a GOD !Wealth Manager Is a GOD !
A lot of people will disagree with this…….if ur seeing 1.3-1.4 bars at time, 1.5 is NOT out of the question…..
Old Dec 30, 2013 | 09:36 AM
  #35
996tt550hp's Avatar
1.3 is his tune and hes hitting 1.5 bars not enough fuel he is leaning what it sounds like.
Old Dec 30, 2013 | 09:46 AM
  #36
Is he on pump and meth or just pump?
Old Dec 30, 2013 | 04:40 PM
  #37
if temps drop enough one can see .1 bar difference usually... often when one lefts off gas it spikes then to .2 bar...
2001 996TT 3.6L and stock ECU
9.66
seconds @ 147.76 mph 1/4 mile
click to view
Old Dec 31, 2013 | 04:27 PM
  #38
mod mike's Avatar
mod mike has a spectacular aura aboutmod mike has a spectacular aura aboutmod mike has a spectacular aura about
happy new year. from the join date looks like you're new to the forum.. welcome.
i'd check your newly installed waste gates. you have a boost controller? if not, thats the first thing i'd order.. 1.5 on any set up is pushing it without knowing where your at. i've read many treads where someone is doing what the group is not doing, and they vanish from the form.. HP #'s, boost set at higher than safe limits; all those other guys were trying to impress people behind a keyboard, people they will never meet.. just saying.. 1.5 in high gears: only a matter of time my friend...
PenguiN
Oct 26, 2018 07:23 AM
markski@markskituning
Aug 24, 2015 10:07 AM
magoochi
Aug 23, 2015 05:54 PM
barncobob
Aug 19, 2015 02:35 PM
