996tt ABS PSM failure
Ok I picked up my repair harness today from the dealer only $118.00 I still feel that the muffed up wire is inside the car. Their are several harness that run under the dash does anyone know the route of the ABS wire once its inside the car.
reliance upon cleaning the maf as a solution might be short lived and add to your confusion if the maf is/was an issue since cleaning it is a temporary stopgap measure. you'll really need to replace it with new ( btw i use the $50.00 generic mafs
) to eliminate the maf as a probable or contributory reason for the cels etc.
randalldahme
Feb 19, 2016 03:56 PM
ModBargains.com
996 Turbo Vendor Classifieds
Oct 1, 2015 11:48 AM
PelicanParts.com
Sep 25, 2015 03:17 PM
