Are there any lightweight flywheels out there...
Old Jan 5, 2014 | 05:31 PM
pwdrhound's Avatar
Originally Posted by Steve K ny
yes, your tuner should be able to take care of this.
when i had my 996, i had a UMW tune with their 964lwfw. the car only chattered when the a/c was on in the summer. probably the best street set up lwfw.
I think Kevin's LWFW tune slightly raises the idle RPM which helps reduce the chatter. When you load up the engine with the A/C the idle rpms drop a little and the chatter is more audible. I have a friend who had installed the UMW LWFW tune on his car that had the stock DMWF and the rpms between shifts just hung up there without barely dropping. Once the DMWF UMW tune was installed all was good. This makes it clear that the LWFW tune takes the much lower mass of the FW into consideration thus preventing the stalling issue many complain about.
Old Jan 6, 2014 | 09:33 AM
wross996TT's Avatar
Agreed with both posts above. Kevin tuned mine to take into account the LWFW....works great.
Old Jan 6, 2014 | 04:01 PM
RS4Me's Avatar
RS4Me is infamous around these parts
Originally Posted by TXTurbo996
Ha! I live in TX, I don't the a/c is ever off!
Well, I've already purchased the Sachs 2.5, which should work with the stock flywheel and doesn't require any conversion. Sigh. I guess I could go with GT2RS intercoolers and not add any weight to the rear.
I have a Sachs 2.5 with a LFW and would never do it again. Living in Dallas in this heat the chatter is loud. Clutch yes, fly wheel no.
Old Jan 6, 2014 | 06:33 PM
pwdrhound's Avatar
The amount of chatter has a lot to do with the type of clutch disc that is used. What kind of disc are you running? "Stage 2.5" means nothing. It's just a designation used by vendors that market aftermarket kits but does not tell you what components are used. Where your tuner sets the idle will also play a part in the amount of chatter. Do you have a lwfw specific tune?
Old Jan 7, 2014 | 11:23 AM
RS4Me's Avatar
Kit from AWE. The OP asked a question and I answered. This is my opinion of my car. I live in Dallas so if the OP wants to check out my car and the chatter he can. You said in a previous post there is chatter in LWFW's. This is subjective just like drone on exhausts. I don't want the rpm's higher just to diminish the chatter, I can use the radio for that. It's not a bad setup just noisy and not to my personal taste.
Old Jan 7, 2014 | 11:44 AM
TXTurbo996's Avatar
TXTurbo996 has much to be proud ofTXTurbo996 has much to be proud ofTXTurbo996 has much to be proud ofTXTurbo996 has much to be proud ofTXTurbo996 has much to be proud ofTXTurbo996 has much to be proud ofTXTurbo996 has much to be proud ofTXTurbo996 has much to be proud ofTXTurbo996 has much to be proud of
I also bought my kit from AWE. I'd love to hear it, I'll send you a PM to see if we can set some time up to check your car out, I'm in McKinney.
Old Jan 7, 2014 | 12:52 PM
zmt's Avatar
zmt
zmt is infamous around these parts
We should all get together sometime and compare what's unique about our cars (I have the DCTMS smaller steering wheel and 997 shifter assembly, for instance). I'd also like to see how a LWFW feels/sounds.
Old Jan 7, 2014 | 04:35 PM
TXTurbo996's Avatar
Agreed... when this deep freeze is over and temps return to a more reasonable number LOL
Old Jan 7, 2014 | 05:33 PM
Tim941NYC's Avatar
I just breezed through this thread.. I would use the 964rs. Call Don at EBS. http://www.ebsracing.com/
Ask him about it. Also ask about the Kennedy sprung disc, it will hold more torque then most other discs out there..
Old Jan 7, 2014 | 06:51 PM
RS4Me's Avatar
Gents,
Let me know when and where and I'll be there.
Old Jan 7, 2014 | 07:37 PM
stilov's Avatar
stilov Is a GOD !stilov Is a GOD !stilov Is a GOD !stilov Is a GOD !stilov Is a GOD !stilov Is a GOD !stilov Is a GOD !stilov Is a GOD !stilov Is a GOD !stilov Is a GOD !stilov Is a GOD !
I'm in...I really should be out in the garage putting my rear bumper back on. Just not motivated today.
Old Jan 10, 2014 | 05:41 PM
TXTurbo996's Avatar
As an update... I got my Awe Tuning Sachs 2.5 clutch kit in the mail today. It's got the 764 pressure plate, but the clutch disc is solid. There's no way I'd want to go with a LWFW now. I thought the disc would be a sprung hub. Oh well.
Old Jan 10, 2014 | 05:50 PM
pwdrhound's Avatar
DMFW use a solid disc, LWFW use a sprung. Does AWE market that kit with the solid disc for LWFW use??
Old Jan 10, 2014 | 06:03 PM
TXTurbo996's Avatar
As far as I can tell from their website, yes. It does not say whether they use a sprung hub if you buy the Sachs 2.5 kit with their 12lb aluminum LWFW.
From the pics though, the 2.5 kit comes with a solid disc only.
Old Jan 10, 2014 | 06:28 PM
pwdrhound's Avatar
And that's exactly why some people have such a lousy experience with some of these vendor stage xx clutch "kits" out there. A solid disc coupled with a LWFW will be much noisier with worse drivability compared to a correct sprung disc set up. Many vendors of shops will sell you a stage xxx kit without really understanding what parts will work well together and which won't. Just because it bolts up doesn't mean it will work well. Caveat emptor... Kevin at UMW sells some great proven clutch packages...
