Reading Durametric Programming....
Old Jan 13, 2014 | 06:11 PM
GTLaser's Avatar
GTLaser is a splendid one to beholdGTLaser is a splendid one to beholdGTLaser is a splendid one to beholdGTLaser is a splendid one to beholdGTLaser is a splendid one to beholdGTLaser is a splendid one to beholdGTLaser is a splendid one to beholdGTLaser is a splendid one to behold
Looking at a Porsche and I asked to confirm the mileage. Was sent a pic of the Durametric Programming and need help reading the data. Sent an email to a local Indy Porsche shop but thought maybe someone here can also clarify. Trying to determine what the two over rev data is showing, what do those two numbers show? Thanks!
Old Jan 14, 2014 | 08:38 AM
i have actually never seen that screen in durametric
#TeamAIM
Old Jan 14, 2014 | 12:21 PM
rob001's Avatar
rob001 is infamous around these parts
.. and the fact you can change data such as over-revs and total distance.....
Old Jan 14, 2014 | 12:22 PM
you actually cant. buttons are there but you cant make changes. vagcom had simialr things in place.
#TeamAIM
Old Jan 14, 2014 | 01:37 PM
mbgt72's Avatar
mbgt72 has much to be proud ofmbgt72 has much to be proud ofmbgt72 has much to be proud ofmbgt72 has much to be proud ofmbgt72 has much to be proud ofmbgt72 has much to be proud ofmbgt72 has much to be proud ofmbgt72 has much to be proud ofmbgt72 has much to be proud of
I'm guessing that's not an actual durametric program, but moreso a shop tuning / reading program.
Interesting nonetheless.
I'd really like to see if it actually lets you over-write the rev counts though. I've seen similar things that have the button there but don't let the program actually do anything as prodigymb suggests, but there are also cases where it will actually let you change mileage etc (obviously illegal, but such programming does exists -> click here ).
I take it the car you're referencing is tuned? That'd be the only way I could imagine that many Rev1 / Rev 2 as some tunes raise the rev limit slightly, but the Rev 1 / Rev 2 don't adjust accordingly.
Old Jan 15, 2014 | 06:34 PM
rangerdick's Avatar
rangerdick has a spectacular aura aboutrangerdick has a spectacular aura aboutrangerdick has a spectacular aura about
That's a huge number of type 2 over revs. Each "over rev" is a spark ignition. 6 sparks per two revs of the crank means like 3400 revolutions above type 1 over rev. That's like 30 seconds above 7000 rpm. All the rev's, both type 1 and type 2 occurred at the same incident.
Old Jan 19, 2014 | 01:07 AM
Duane996tt's Avatar
Duane996tt has a reputation beyond reputeDuane996tt has a reputation beyond reputeDuane996tt has a reputation beyond reputeDuane996tt has a reputation beyond reputeDuane996tt has a reputation beyond reputeDuane996tt has a reputation beyond reputeDuane996tt has a reputation beyond reputeDuane996tt has a reputation beyond reputeDuane996tt has a reputation beyond reputeDuane996tt has a reputation beyond reputeDuane996tt has a reputation beyond repute
On a completely stock car type 1 over revs can be achieved at will in upshifts. Type 2 over rev are usually also upshift, not down shifts. With this read out, you don't have any major issues to worry about, except a stressed clutch. If you put a tune on the car, then you'll have tons of type one and two upshifts and even type three upshift depending on the tune.
Old Jan 20, 2014 | 10:23 AM
winnigt2's Avatar
winnigt2 has a reputation beyond reputewinnigt2 has a reputation beyond reputewinnigt2 has a reputation beyond reputewinnigt2 has a reputation beyond reputewinnigt2 has a reputation beyond reputewinnigt2 has a reputation beyond reputewinnigt2 has a reputation beyond reputewinnigt2 has a reputation beyond reputewinnigt2 has a reputation beyond reputewinnigt2 has a reputation beyond reputewinnigt2 has a reputation beyond repute
during the last time i have seen offers for reset over rev counter motronic 7.8 996tt, so it is possible to do it
Old Jan 20, 2014 | 10:29 AM
buzzm's Avatar
buzzm Is a GOD !buzzm Is a GOD !buzzm Is a GOD !buzzm Is a GOD !buzzm Is a GOD !buzzm Is a GOD !buzzm Is a GOD !buzzm Is a GOD !buzzm Is a GOD !buzzm Is a GOD !buzzm Is a GOD !
it says 'this function allows you to modify the engine abuse information' that sounds sketchy as hell, if it says that right on the screen then i would assume its possible do that, why would it say it if it isnt possible
Old Jan 20, 2014 | 10:47 AM
dynamic gt2's Avatar
dynamic gt2 is a splendid one to beholddynamic gt2 is a splendid one to beholddynamic gt2 is a splendid one to beholddynamic gt2 is a splendid one to beholddynamic gt2 is a splendid one to beholddynamic gt2 is a splendid one to beholddynamic gt2 is a splendid one to behold
how do we access to this option?
BLKMGK
May 31, 2016 04:32 AM
vogz
Sep 19, 2015 01:02 PM
jdbaker
Sep 19, 2015 10:34 AM
arhim22
Sep 7, 2015 08:49 PM
Suds26
Sep 2, 2015 01:33 PM
