GT3 Group Buy seats starting to ship!!!
Old Nov 7, 2003 | 08:14 AM
rockitman's Avatar
rockitman has a reputation beyond reputerockitman has a reputation beyond reputerockitman has a reputation beyond reputerockitman has a reputation beyond reputerockitman has a reputation beyond reputerockitman has a reputation beyond reputerockitman has a reputation beyond reputerockitman has a reputation beyond reputerockitman has a reputation beyond reputerockitman has a reputation beyond reputerockitman has a reputation beyond repute
Thumbs up GT3 Group Buy seats starting to ship!!!
Just got a call from Mark @ FA... My black leather seats are shipping today with an estimated delivery of 3 days...FYI
Can't wait!!!
Old Nov 7, 2003 | 08:37 AM
JASCLASS's Avatar
JASCLASS is infamous around these partsJASCLASS is infamous around these parts
Nice Rockit, Things are comming together, GT3 seats, Rollbar, and console delete.
Old Nov 7, 2003 | 08:46 AM
Sloth's Avatar
Sloth has much to be proud ofSloth has much to be proud ofSloth has much to be proud ofSloth has much to be proud ofSloth has much to be proud ofSloth has much to be proud ofSloth has much to be proud ofSloth has much to be proud of
Going for a ride to pick mine up at the shop tomorrow.
Install on Sunday... or maybe Saturday night...
Old Nov 7, 2003 | 08:54 AM
rockitman's Avatar
Yeah, I am starting my training regiment for the rollbar/GT3 seat installation marathon. Feeling pretty loose and confident...
Guess I will need to get a nice fire extinquisher mounted to the roll bar, followed by the GT3RS CF wing element and perhaps mirror's and hood once Gert has them available.
The GruppeM ram air/cone filter system may be nice too. I should hear back from them next week regarding any valid performance documentation. Not as concerned about the hp increase, minimal at best, but significantly enhanced throttle reponse time and sound could put me over the $1,600 abyss for that mod
Besides, the CF really dresses up the engine compartment. Sort of the "Black Tie" look....
Where does the modding end??? It seems like when your done with one thing, your ready for the next....Funny!!!
Old Nov 7, 2003 | 08:57 AM
rockitman's Avatar
Max, let us GT3 guys know if you run across any install snafu's, particularly the disconnecting and reconnecting of the seat belt wire harness. I sure don't want to screw that up and have the air bag light go off...
Old Nov 7, 2003 | 09:16 AM
Sloth's Avatar
It seems that the important part is to hook up the seatbelt harness the right way. Photos will be taken and the harness will be marked before I pull any plugs.
Old Nov 7, 2003 | 09:19 AM
rockitman's Avatar
Great idea. I will do the same...Post one if it's convenient....Good luck...
Old Nov 7, 2003 | 01:10 PM
MTBR's Avatar
MTBR is infamous around these parts
It's very simple.
Put a blanket down and cover both door sills to prevent any damage, i.e. scratching.
A. Make sure the key is out of the ignition
B. Remove 4 torx bolts per seat
C. Unplug wiring harnesses
D. Open each harness (slide lock) and remove seat belt wire/plug
(simply disconnects with no cutting, etc.)
E. Remove seatbelt receptacle from each seat and attach to GT3 Seat
F. Bolt new GT3 seats in place
E. Connect seat belt wire/plug into floor wiring harness and tape together
F. Enjoy a beer
If you are installing the sub bars, the time to do it is now, BEFORE bolting down the GT3 seats.
The whole thing will take you ~30 minutes - 1 hour, depending on how slow you go.
Old Nov 7, 2003 | 04:36 PM
rockitman's Avatar
Originally posted by dan996tt
B. Remove 4 reverse torx bolts per seat
What's the difference between reverse torx and regular torx bolts???
Are there such things as english vs. metric torx???
Can you use the standard allen wrench style torx key or do I need a special tool???
Thanks..
"Tool Challenged"
Old Nov 7, 2003 | 05:36 PM
MTBR's Avatar
You would need a "reverse" torx socket which is "female"
You cannot use an allen wrench style torx key.
A picture of a torx bolt similar to the one you will be removing:
Old Nov 7, 2003 | 06:56 PM
Sloth's Avatar
In the past I have been able to get the bolts loose using a regular socket, though I am sure the correct tool makes it much easier.
Old Nov 7, 2003 | 07:05 PM
rockitman's Avatar
Cool!!!! Looks like a new tool for the tool box. I understand the reverse part now. Thanks Dan !!!!
COBB Tuning
Jan 1, 2025 09:02 AM
The_Ruski_Driver
Oct 25, 2015 08:40 PM
pwdrhound
Aug 20, 2015 05:54 AM
PelicanParts.com
GT3/GT2/GT Vendor Classifieds
Aug 18, 2015 03:42 PM
