Tire question
Tire question
I've been looking on some of the previous threads and using the search function and I may have missed the answer and if so I apologize. I'm going to need rear tires soon. I'm running stock 18's with Pirelli's. 225/40 and 295/30. The fronts have more to give and I'm okay getting rears and then trying something else. My question is can I run 315's on the rear with the 225's up front? I've read that 235 & 315 works. I've got a lot to learn and this is a great place to get some great answers. Love the look of the 315's in the rear. Options? Thanks.
225 and 315 doesn't matter, thats more width of the tire.
its the 25/30/35/40 that matters (height). Run a 25 to 30 rear and 30 to 35 up front and you should be fine. I forget the exact percentage needed to not affect the diff. Some people say its a farce but most people follow the rule of thumb.
pretty sure that 3% difference in rolling diameter limit is not myth, but a rule to be followed. running the 225/40 will not cause differential issues, but you'll probably see abs/psm cels until the new rears get scrubbed. not to worry, the car is very sensitive to new tires against old(er) ones *intially*.
me, i would get rid of the oem pirelli's owing to their age, assuming they are still from the stock fitment(?). if not?, the assyms are a very solid tire choice for DD'ing.
I was looking at the paper work last night and the tires were installed in 2010. No mileage was indicated at the time which I thought was strange. Four years old? All of my other paper work is spot on and the car is in great shape with only 20,000 when I bought it. I've put almost 3,000 on the car since November. Love to drive it. So now if I change all four I can go to 235/335. Then the tire dilemma begins! Choices?
OP, your best bet is to check the tire spec sheets from the manufacturer for diameter, then try to keep it within 3% F and R with the front slightly taller. To understand the reason for this fully real about viscous coupling awd. The tire diameter given by a manufacturer may not be the diameter you will see because the width of the rim used will effect the actual diameter.
I'm on stock 18's I believe. So 8's and 11's. I was thinking of changing wheels maybe as well. If I go with the 235/315 on new wheels then should I go to 8.5-9's on the front and 12's on the rear? Then offsets? New territory for me. I've read about the 3% difference and will be sure to keep it that way. Steve K it was your post that made me decide to go to 235/315. I've read many posts about this but still I'm a slow learner.
The big reason I am running 19's is because of the tire choices. I wanted to run Michelin Pilot Super Sports and they weren't available in 18's in the appropriate widths.
So in doing some more research it looks like the Pirelli Rosso's in 315 are my only choice if I stay with my P-Zero fronts. Any problem with the different tread design running Zero's up front and Rosso's in the rear?
I've run 295, 305, and 315 rears and definitely notice the additional grip of the 305, and the extra grip of the 315 beyond that, but have gone to focusing much more on tire performance/tread/compound over size. Personally I now run Toyo R888 semi-slicks/rain track tires on the street as my summer tires, and as my track tires too. They're the stock size 225/40 and 295/35 on a set of 18" OEM hollow spoke Turbo twists I picked up from another member on the board here. We don't get much rain in CO summers so the lack of water channels doesn't really affect me. I may go up to a 235/305 combo for my next set, but in the stock size I already get a lot of grip even with my upgrades (I'm at ~600 hp/tq).
One last factor to consider is different model tires of the same listed width aren't necessarily the same actual width, so without actually measuring the tires, you can't compute an accurate difference in rolling diameters. Normally each manufacturer will use the same standards for measuring the widths, especially for the same class of tires (high-perf summer, all-season, winter, etc), so your risk can be limited, but that's not always the case.
Scott, thanks for the thorough answer! I love it. I'm thinking the best way to go is to replace all four tires. I want more width on the rear's and in researching on Tire Rack I found that the Advan AD08R in 295 gives me the width I am looking for. The tires have gotten some nice reviews. I'm not planning on tracking the car anytime soon so just some spirited canyons on the weekends. Tire diameters are the same for F/R.
FWIW, the new Pilot Super Sports have been getting all of the best reviews by far of any of the tires available for our cars. If I still ran street tires at all, those would be my choice for sure.
To bad they don't have the 295/30/18's. Tire Rack only goes to 285's. I know the reviews have been great.
Jim
