coolent pipe bonding
Old Feb 16, 2014 | 11:05 AM
pat's Avatar
pat
pat has a reputation beyond reputepat has a reputation beyond reputepat has a reputation beyond reputepat has a reputation beyond reputepat has a reputation beyond reputepat has a reputation beyond reputepat has a reputation beyond reputepat has a reputation beyond reputepat has a reputation beyond reputepat has a reputation beyond reputepat has a reputation beyond repute
Either method is similar for time.
Old Feb 16, 2014 | 04:24 PM
joetwint's Avatar
joetwint Is a GOD !joetwint Is a GOD !joetwint Is a GOD !joetwint Is a GOD !joetwint Is a GOD !joetwint Is a GOD !joetwint Is a GOD !joetwint Is a GOD !joetwint Is a GOD !joetwint Is a GOD !joetwint Is a GOD !
Originally Posted by 32krazy!
so you spent countless time cleaning each fitting, mixing the jb weld applying it liberally all over inside and out. let it dry for a complete day then spent more time cleaning the inside of each fitting to ensure the passage isn't blocked and now will drill and pin each fitting to ensure you can race.
seems like the 2 hrs my shop spent welding the fittings was money well spent!
I would think your shop spent the time cleaning them too otherwise your gonna start getting pinhole leaks where the weld did not adhere.I have mine welded but this method does work (and last).I have seen heavy machinery fittings repaired this way and have lasted a long time running 24hrs 7 days.
Old Feb 16, 2014 | 06:12 PM
pat's Avatar
pat
I am doing the other ones tonight
ID:	334789   Click image for larger version
ID:	334790   Click image for larger version
ID:	334791   Click image for larger version
Old Feb 16, 2014 | 06:21 PM
pat's Avatar
pat
ID:	334798   Click image for larger version
ID:	334799   Click image for larger version
ID:	334800   Click image for larger version
Old Feb 16, 2014 | 06:25 PM
pat's Avatar
pat
More pictures
ID:	334802   Click image for larger version
ID:	334803   Click image for larger version
ID:	334804   Click image for larger version
Old Feb 16, 2014 | 06:35 PM
pat's Avatar
pat
One of these came out with a twist the others needed heating with a propane torch. The insides were very smooth. Not good do bonding.
ID:	334806   Click image for larger version
ID:	334807   Click image for larger version
ID:	334808   Click image for larger version
Old Feb 16, 2014 | 08:39 PM
02black330ci's Avatar
02black330ci Is a GOD !02black330ci Is a GOD !02black330ci Is a GOD !02black330ci Is a GOD !02black330ci Is a GOD !02black330ci Is a GOD !02black330ci Is a GOD !02black330ci Is a GOD !02black330ci Is a GOD !02black330ci Is a GOD !02black330ci Is a GOD !
Very nice DIY OP. Having these welded are on my todo list, but if I am up for it, I might go this route.
Old Feb 16, 2014 | 09:41 PM
32krazy!'s Avatar
hit all the fittings with a hot propane torch and they came right out. buffed them with a wire brush on a drill and welded them up.
i could see doing this method if a single fitting came out but if the motor is already out the work doesn't justify the time when wedding is a much better way to go, but just my .02
Old Feb 16, 2014 | 09:57 PM
TeCKis300's Avatar
TeCKis300 is a glorious beacon of lightTeCKis300 is a glorious beacon of lightTeCKis300 is a glorious beacon of lightTeCKis300 is a glorious beacon of lightTeCKis300 is a glorious beacon of light
If welding, is there a need to pull the fittings out at all?
Old Feb 17, 2014 | 06:54 AM
IITURBO's Avatar
IITURBO is a name known to allIITURBO is a name known to allIITURBO is a name known to allIITURBO is a name known to allIITURBO is a name known to allIITURBO is a name known to all
I agree.
Old Feb 17, 2014 | 08:10 AM
Tim941NYC's Avatar
Yes. As Joe said, if you do not clean all the glue out it will burn and contaminate the weld and cause porosity in the weld.
Old Feb 17, 2014 | 08:16 AM
Tim941NYC's Avatar
The most common one is the one behind the alternator. Item in your 1st pic. Why? That 3/4 90 degree fitting bypasses the radiators and goes to the heater core, it sees high temps then the rest of the glued fitting
Old Feb 17, 2014 | 09:39 AM
pat's Avatar
pat
The elbow went last year and the year before on my other car. Both times I was autocrossing. With the same club.( the corvette club. At least I had ftd.) When the other one went I was at ginger man track.
Old Mar 2, 2014 | 06:11 PM
pat's Avatar
pat
Pined and ready to go.
ID:	341218   Click image for larger version
ID:	341219   Click image for larger version
Old Mar 2, 2014 | 07:29 PM
jpflip's Avatar
Great job Pat!
