First time at a drag strip, help me out
I friend with a 2014 GTR and Switzer P800 kit wants me to run him. (Probably to make him feel good). Supposed to head over to Montgomery AL on Friday.
I have never really driven on the track. Need some tips, pointers, etc.
My car:
2001 996 T with:
Sambo Billet K16's
911 Tuning inlet pipes
GT2RS IC's
KW V3 coilovers
19" wheels right now on Nitto Invo's 305/30/19
(1st question is, would I be better to put my 18" stock wheels on with the ancient Hancook Ventus Evo tires they have now?)
RWD Conversion
I've read to turn PSM off. What else?
My car:
2001 996 T with:
Sambo Billet K16's
GT2RS IC's
KW V3 coilovers
RWD Conversion
Usaully 18s are always better but if tires on them are shot than stick with your 19s.
PSM off. around 25-26psi in tires, make sure they are even.
#TeamAIM
#TeamAIM
If I can get them done before Friday afternoon. What size/kind of drag radials should I put on my stock 18" wheels?
Can I get away with 18" rears with Drag Radials and my 19" wheels up front? (RWD car)
i would do the 305/35/18 Mickey .... pretty common tire
#TeamAIM
#TeamAIM
you could but in drag racing you want the extra sidewall of a 35 profile vs 30 profile tire.
#TeamAIM
#TeamAIM
drop the pressure in rear to 22 psi lets say....don't wheel hop- axles go...
2001 996TT 3.6L and stock ECU
Any way to avoid wheel hop? Or will the lower pressure help me with that?
yeah more sidewall on tires. nice motor and tranny mount as well as solid subframe bushings and nice suspension arms. all those help.
#TeamAIM
#TeamAIM
You have to find the sweet RPM spot to bring the Rpms up to with the gas pedal ,,, then let up on the clutch to the point where it is just about to grab,, then asi you start to move with the clutch pedal being released give it more of the gas pedal to the floor ... It should be a smooth transaction of those two working together to give you a nice launch.
Good luck,, practice makes perfect..
HIX, youre better off with 18s and a 35 profile tire. (305 35). a thin sidewall wont give you enough flex to come off the line strong, and it may increase wheel hop. too much wheel hop and your axle snaps.
