Alternator Failing... can I drive it..?
Old Mar 6, 2014 | 07:31 PM
996tt550hp's Avatar
996tt550hp has a reputation beyond repute996tt550hp has a reputation beyond repute996tt550hp has a reputation beyond repute996tt550hp has a reputation beyond repute996tt550hp has a reputation beyond repute996tt550hp has a reputation beyond repute996tt550hp has a reputation beyond repute996tt550hp has a reputation beyond repute996tt550hp has a reputation beyond repute996tt550hp has a reputation beyond repute996tt550hp has a reputation beyond repute
Originally Posted by '02996ttx50
i'm not gona flatbed this thing. would you guys "drive to workshop"?
i think the wire runs across motor from trans got pinched.
No u can drive it your fine.
Old Mar 6, 2014 | 07:32 PM
32krazy!'s Avatar
but wouldn't the handheld tester show a load/no load issue with the alt IF it were bad?? :
no the battery and the alternator need to be put under a load to see f they are failing. this is easily done at auto zone or advance auto if you can remove them.
simply testing with a m/m may not show the issue
Old Mar 6, 2014 | 07:55 PM
'02996ttx50's Avatar
i'm not a wrencher just a sh*t talker. so no choice, i gotta take it in. but i thought that aaa's handheld had a load/no load feature. i was over the guys shoulder watching it the alt tested at 13.8 or.9 under load. either way, it's gotta be wrenched.. again. irony is.. car has never been better. you're gonna love that that wavetrac. it's astonishing.
it's real easy to see how i could've further loosened an already loose wire exploring the newfound "limits" of rwd with the tbd
thx for the help fellas.
Old Mar 11, 2014 | 04:03 AM
new bosch ALT part supercedes the older 996 part = 997-603-012-09-M14 for 6MT. $428 shipped at pelican. was hoping it was a ground strap or cable corroded. just not that lucky ..
Old Mar 11, 2014 | 10:40 AM
VAGscum's Avatar
On the topic of alternators, autozone and several other place sell Bosch alternators. Has anybody checked to see if they carry ours? You can usually cut the Porsche price in half for the exact same part. Unless of course you have to have it in a Porsche box . They had alternators for my Audi and Volkswagen and it was the exact same. Just a thought.
Old Mar 11, 2014 | 11:30 AM
good advice. though i'm fairly certain 428 no shipping is about the best we could hope for a new bosch. after the way my car runs after FINALLY running the bosch oem, i'm liking that yellow oem box.
Old Mar 11, 2014 | 12:30 PM
996tt550hp's Avatar
Search for people that tried autozone it didnt work out for them very well. It's not your alternator i thought it was mine and i found a loose wire. If you want to just replace the regulator its 36.00 dollars but its not the problem.
Old Mar 11, 2014 | 12:40 PM
i've watched carefuly how it failed, and am as sure as i can be it isn't a cable or ground or power wire to starter being loose. after a week of having the light go on/off and volts fluctuate down to 11.8! i tried to start it with all lights on and it finally "went", and now battery fail light is solidly ON. it's also not worth it to just replace the VR since the alt has to come out anyway and the new one obviously has a new volt reg too.
with 111k miles, even if it isn't the alternator that failed, it has outlved its normal life so for the $428 its time and a simple r&r.
Old Mar 11, 2014 | 01:03 PM
996tt550hp's Avatar
I just hope you get it fixed see if it is that i know i had the same results and it wasnt the alternator. Remember you can have burnt wires or loose connection anywhere im lucky to find mine quickly please keep us posted.
Old Mar 11, 2014 | 02:07 PM
i will, thanks. i'm curious though..? why are you acting as if it is unlikely that it COULD be the alternator? lol. it's not as if they don't "fail"!
Old Mar 11, 2014 | 02:12 PM
996tt550hp's Avatar
When they fail the voltage does not go back up to 13.8 and bounce around thats a sign of a bad wire. When this exact same thing happened to me i founf my alternator wire loose also had corrosion on it.
When my other porsche alternator failed i start the car then after 10 min it starts to drop to 12.5 volts and never went back up unless the regulator cools off thats what goes on these alternators its the heat. When i did the load test at autozone it said failed the battery was not charging.
Old Mar 11, 2014 | 02:31 PM
i hear ya. but you missed the bit about after a few days.. it no longer bounces back up. it's full fail, engine on, volts at 11.8 and dash light red.
that's when i ordered the new alt. i'll have it on tonight and will let ya know, but i'm confident the new part will do it. even if it was a voltage reg, i'll have both new with the new alt. the thing is, i have over 100k miles on the car, i drive it hard every day, and sh*t breaks so i pay to play.
Old Mar 11, 2014 | 09:34 PM
new bosch alternator r&r'd in 57 minutes in semi darkness in my driveway with bats ( literally ) flying and dive bombing from above. amp gauge is SOLID 14 idling. 13.8 with lights on.
problem solved!
Old Mar 12, 2014 | 09:32 AM
VAGscum's Avatar
Links? A Bosch alternator is a Bosch alternator regardless of the box it comes in. Maybe they used an off brand?
Old Mar 12, 2014 | 09:44 AM
it is fairly difficult to source a NEW bosch as there are lots of online sellers with bosch rebuilts. even from bosch...but pelican got me one in 24 hours.
even the bosch oem box made a point of the word "NEW" on it, which i've never seen before.
pwdrhound
Sep 16, 2021 02:27 PM
mikerosi
Dec 6, 2018 06:23 PM
