next mod?
next mod?
I have an 02 turbo tip with intake and a 1 bar tune. The car ran 12.1 at 117 mph last night at the strip. Ran several times but couldn't break into the 11's . Will an exhaust or muffle delete make a big difference and shave a couple of tenths? Or should i just boost a little more? Let me know what you guys think or suggest.
Gotta look into that. Didn't think about that when I got the tune
60 foot is not bad, 1.9, but can use some work. If you get that down to even 1.7, you will hit a high 11s as is. As others have said though, if you add the exhaust that should easily put you there also.
Exhaust will make a difference but not 2 tenths. You need some upgrades like bigger turbos, injectors, upgraded torque converter, upgraded intercoolers, upgraded boost hoses, 1 bar wastegates, 710N diverter valves and so on....... K16s just dont have enough flow.
Whats the accepted best way to launch a 996T (6 speed) at this state of tune, I was struggling to get under 2 secs but with an exhaust and similar tune was running 12.1 @ over 125mph regularly, seems it either bogs or gets a lot of axle tramp.
K16s can run 11's with a flash and exhaust, and an exhaust can certainly net .2 in the 1/4 with these cars.
Thats a good trap speed! Would love for mine to have that trap speed.I know most of the Z06's I ran were faster cars because of trap speed but they couldn't launch. I made a bunch of them look bad. car is a tip so there is only so much brake boost I can do. My car would start moving forward when I stepped on the accelerator and went over 1800 rpm Before launch. Maybe I need better brakes... :/
sdg1871
Dec 24, 2015 12:22 PM
