LUK and Porsche dual mass flywheel same?
Old Apr 4, 2014 | 07:01 PM
Wealth Manager's Avatar
Wealth Manager Is a GOD !Wealth Manager Is a GOD !Wealth Manager Is a GOD !Wealth Manager Is a GOD !Wealth Manager Is a GOD !Wealth Manager Is a GOD !Wealth Manager Is a GOD !Wealth Manager Is a GOD !Wealth Manager Is a GOD !Wealth Manager Is a GOD !Wealth Manager Is a GOD !
I understand LUK makes the flywheel for porsche. So if I buy the stock dual mass flywheel by LUK its the same thing as the porsche turbo stock flywheel?
Seems this is what I have been told by distributors and the parts numbers match up for OEM.
I am trying to get a 996 turbo stock dual mass flywheel. Thanks!!
Old Apr 4, 2014 | 07:14 PM
Also, did anyone ever test the strengths of the stock dual mass flywheel?
Old Apr 4, 2014 | 07:32 PM
32krazy!'s Avatar
i have a oem you can have used if you want it
Old Apr 4, 2014 | 07:33 PM
pwdrhound's Avatar
LUK is oem supplier to Porsche. I have an OEM DM fly wheel if you need one
Old Apr 4, 2014 | 07:44 PM
PM'd you guys......
Old Apr 4, 2014 | 08:42 PM
'02996ttx50's Avatar
i'm told i have roger rodas old stock and basically new dmfw in my car now. i was too cheap to buy a "new" one when i put in the new gt2 clutch, and it was just sittin around. so why not.
i haven't tested its strength, but it seems to handle 500 whp just fine
Old Apr 4, 2014 | 09:09 PM
teflon_jones's Avatar
teflon_jones Is a GOD !teflon_jones Is a GOD !teflon_jones Is a GOD !teflon_jones Is a GOD !teflon_jones Is a GOD !teflon_jones Is a GOD !teflon_jones Is a GOD !teflon_jones Is a GOD !teflon_jones Is a GOD !teflon_jones Is a GOD !teflon_jones Is a GOD !
I don't know why anybody would put in a used, relatively cheap part when the labor is a few thousand bucks, especially when you should resurface a FW if you're going to use it again. Just put in a new one and call it a day. Preferably a LWFW so you get better performance!
But if anybody wants a stock DMFW I have one for free for any takers...
Old Apr 4, 2014 | 09:14 PM
The only way I would take a stock DMFW from someone is if it was new. I simply asked questions about who makes them and how durable.
Old Apr 5, 2014 | 05:17 AM
i can answer that! after several grand on my trans work/lsd and assorted other 100k+ mile upgrades, finding i needed a new FW with my other new clutch parts and my techs having a nearly new one on the shelf that even had "provenenace" of a somewhat dubious nature still seemed like a smart move at the time. apparently rodas had taken it out of his 996 before it was used/abused and there it sat. until i needed it, and my clutch was already "out" anyway. sometime you go with what ya got, provided nothing else will "suffer". i had a stock dmfw before,.. and still do.
my clutch works just fine and like new, so it turned out to be a wise decision. so far
Old Apr 5, 2014 | 06:07 AM
32krazy!'s Avatar
unless you have changed you plans for a triple disk c/f clutch i don't think you can even run a dm/fw. the c/f clutch comes with a basket style flywheel. basically a steel or aluminum lwfw that has a cage around it to house the multiple plates and the p/p is attached to the cage.
now if you have changed to a single disk organic style clutch then the oem flywheel will work. either way if you want my old unit its yours i have no need for it. i also have the p/p but the disk is toast
tropicatango
Jun 8, 2025 01:00 PM
joseph_number1
Jul 19, 2018 05:45 PM
TrackOne
Aug 20, 2015 12:56 PM
Vrseis
Aug 20, 2015 07:41 AM
