Clutch Issue
Old Apr 5, 2014 | 12:30 PM
Montescew's Avatar
Montescew is infamous around these parts
Clutch Issue
Hi Guys,
I own a '01 TT w/ 17k miles. About 8-10 months ago my clutch became very stiff before starting the car and would occasionally loosen up from time to time, if left off for an hour or two it would generally tighten up again. Once started it's typically fine but does make an annoying sound on occasion.
The information I have read would make me lean toward the accumulator, but wanted to run this by you guys first. Is it typically just the accumulator or slave too? Any steps I can take to diagnose what might be going on? Is it okay to drive the car like this??
Thanks!!
Old Apr 5, 2014 | 12:47 PM
rmc1148's Avatar
Replace both use search more info on this then about everything else combined.
Old Apr 5, 2014 | 03:09 PM
996tt550hp's Avatar
996tt550hp has a reputation beyond repute996tt550hp has a reputation beyond repute996tt550hp has a reputation beyond repute996tt550hp has a reputation beyond repute996tt550hp has a reputation beyond repute996tt550hp has a reputation beyond repute996tt550hp has a reputation beyond repute996tt550hp has a reputation beyond repute996tt550hp has a reputation beyond repute996tt550hp has a reputation beyond repute996tt550hp has a reputation beyond repute
Replace accumulator its takes 5 minutes.
Old Apr 5, 2014 | 03:41 PM
johnspeed's Avatar
And replace the slave..
Old Apr 5, 2014 | 05:29 PM
'02996ttx50's Avatar
agree with everyone. replace all at one time. nothing worse than replacing the cheaper accumulator, only to have to buy and r&r the slave a few weeks later.
there are countless threads in here since this has been happening to us for over ten years. search clutch and clutch slave n here. easy fix. you can drive it if it's just stiff. but only for a short period of time since sometimes when these things fail completely? pentosin goes with it. a mess.
change em out. and gl
Old Apr 6, 2014 | 07:14 AM
Empyreal's Avatar
Empyreal is a splendid one to beholdEmpyreal is a splendid one to beholdEmpyreal is a splendid one to beholdEmpyreal is a splendid one to beholdEmpyreal is a splendid one to beholdEmpyreal is a splendid one to beholdEmpyreal is a splendid one to beholdEmpyreal is a splendid one to behold
Originally Posted by Montescew
Hi Guys,
I own a '01 TT w/ 17k miles. About 8-10 months ago my clutch became very stiff before starting the car and ...
I'd take a look at the symptoms leading up to only 1300 miles a year. Drive that baby!
Sorry. GL with the recommended fixes.
Old Apr 6, 2014 | 01:43 PM
robertg's Avatar
robertg is infamous around these parts
I had the same problem last year. I bought a new accumulator and slave, but just changed the accumulator. It's been good for a year so far.
It could be a five minute job to change the accumulator once you figure out where it is, and make a tool to change it. The new one had a different size hex on it than the old one also.
Old Apr 7, 2014 | 12:31 AM
check if your trans is leaking under... if so its the slave.. must replace it..
2001 996TT 3.6L and stock ECU
9.66
seconds @ 147.76 mph 1/4 mile
click to view
COBB Tuning
Jan 1, 2025 09:02 AM
midwestamv8
Audi
Sep 9, 2015 11:53 AM
LiquidElephant
Aug 27, 2015 06:17 PM
ECS Tuning - VW
Aug 27, 2015 02:44 PM
