Bilstein PSS10's
SubscribeTerminator, Did you have any luck with your complaint to bilstein? If so, do the replaced links seem to be more robust? If not, what did you end up replacing with? I've run into the same issue and I'd like to avoid the units made for the track (Tarret etc.) since I understand they can be noisy on the street.
Thanks!
Thanks!
Quote:
Thanks!
I use TRG's on the front and Tarret's on the rears. No noise issues for 3+ years.Originally Posted by ANJ-911
Terminator, Did you have any luck with your complaint to bilstein? If so, do the replaced links seem to be more robust? If not, what did you end up replacing with? I've run into the same issue and I'd like to avoid the units made for the track (Tarret etc.) since I understand they can be noisy on the street.Thanks!
Quote:
Thanks!
100 plus track hours with Tarett front extended drop links and Tarett rear drop links. Zero noise or any other issues. Make sure you run the rubber end boots on them to seal out dirt and moisture. The byproduct is the fact the boots will dampen any noise if present.Originally Posted by ANJ-911
Quote:
Hi mate. Still waiting for them. They assure me I will get them within next 30 days. And the excuse? Production delay. ;-).Originally Posted by ANJ-911
Terminator, Did you have any luck with your complaint to bilstein? If so, do the replaced links seem to be more robust? If not, what did you end up replacing with? I've run into the same issue and I'd like to avoid the units made for the track (Tarret etc.) since I understand they can be noisy on the street. Thanks!
Ok sounds good Terminator, let us know how it works out!
I think I'm still gonna go with aftermarket links since it seems people have reported the "upgraded" Bilstein links still fail. I'm in between going with Powergrid or Tarret. I like that the powergrids use ball joints and are half the price of the Tarrets.
Porque, any update on how your powergrids are performing now that you've had them installed for a few months?
Quote:
Will do. Is it possible to reach the links and adjust them when the car is on the ground or does it need to be on a ramps or lift to reach them? I'll be installing them on Sunday and would be good to know beforehand.Originally Posted by 996TWINS
When you adjust the drop links, make sure all four wheels are on the ground. You do not want to preload the sway bars.
Quote:
I jack up the car and put the wheels raised up on blocks. Way too tight for me to work under the car otherwise. Originally Posted by ANJ-911
If you really want do it right. Have someone of equal weight sit in the driver's seat while making the adjustments.
