What to do for the 10 year service?
My car is nearly a decade old. However, the millage is still fairly modest ~37K. The 30K service was done by a porsche dealership some three years ago. The car has received annual oil change and inspection since new. I am thinking that in addition to the regular annual service, I should also ask to replace coolant, brake and clutch fluids? Am I missing anything? The differential fluid was replaced at the 30K service. Should I replace the transmission fluid?
Out of interest what else was done by your dealership for the 30k service?
For my 2002 @ 24k miles I've added to my list diverter valves (updated to Bosch 710N's), Boost Pressure Test, main drive belt (because I have to assume that it is as old as the car!) and ball-bearing 2nd gear pop-out prevention trick.
But don't you think that 10 year old coolant should probably be changed? I know that porsche claims it to be a life-long fluid, so perhaps you are right.
It sure wouldn't be a bad idea to change coolant. When I read "vacuumed the radiators" I was thinking removal of coolant. With the car being 10 years old, you could get and unplanned coolant change if one of the engine hoses let go or the plastic end caps on the radiator start leaking. I had a hose burst on my 2003 under CPO at 35000 miles. I also own BMWs which are notorius for plastic end cap radiators failing. I'm replacing mine soon with aluminum ones as preventative maintenance since I track my car.
Here's my list of planned maintenance for later this year...might be overkill for some. Items marked with an * depend on what my mechanic says.
It's a 2003 with 50,000 miles.
water pump
thermostat
belts
radiator fluid flush
trans/diff fluid flush
997 coil packs
spark plugs
boost leaks
fuel filter
* fuel pump
* O2 sensors and MAF
* silicone hoses
* motor mounts
* trans mount insert
* intermediate shaft bearing
* Bosch 710N diverter valves
water pump
thermostat
belts
997 coil packs
spark plugs
boost leaks
fuel filter
* fuel pump
* silicone hoses
* motor mounts
