Diverter valve fluttering?
Old May 7, 2014 | 06:54 PM
TabooPc's Avatar
TabooPc Is a GOD !TabooPc Is a GOD !TabooPc Is a GOD !TabooPc Is a GOD !TabooPc Is a GOD !TabooPc Is a GOD !TabooPc Is a GOD !TabooPc Is a GOD !TabooPc Is a GOD !TabooPc Is a GOD !TabooPc Is a GOD !
Hello everyone,
I'm back in need of more help. I'm currently experiencing a strange sound while I pull in 4th and 5th. It sounds like compressor surge. When I begin to pull in 4th and 5th I hear the sound slowly start at around 0.6 bar. It gets loud at around 1 bar and then goes away by 1.2 bar. My peak boost is 1.3 bar. It also only happens from a low rpm. If I start the pull in 2-3krpm it makes the sound, but if its a shift into 4th from wot 3rd, it doesnt happen.
This doesn't happen in 1st, 2nd, or 3rd. Its the worst in 5th and 6th.
Does this sound like anything in specific?
I cleaned my diverter valves (samco) and nothing changed.
Thanks for any help!
Old May 8, 2014 | 12:05 PM
TabooPc's Avatar
Anyone have any ideas? Todd suggested the actuator preloads arn't in synch, but when I pump them up with a hand pump they both crack at nearly 14psi...
Old May 8, 2014 | 08:40 PM
p556guy's Avatar
p556guy has much to be proud ofp556guy has much to be proud ofp556guy has much to be proud ofp556guy has much to be proud ofp556guy has much to be proud ofp556guy has much to be proud ofp556guy has much to be proud ofp556guy has much to be proud ofp556guy has much to be proud of
I had a fluttering noise that would come on around .6 bar, but I think it was my MAF sensor leaking because the fluttering seems to have stopped since I cleaned and reseated it.
Old May 9, 2014 | 07:06 AM
winnigt2's Avatar
winnigt2 has a reputation beyond reputewinnigt2 has a reputation beyond reputewinnigt2 has a reputation beyond reputewinnigt2 has a reputation beyond reputewinnigt2 has a reputation beyond reputewinnigt2 has a reputation beyond reputewinnigt2 has a reputation beyond reputewinnigt2 has a reputation beyond reputewinnigt2 has a reputation beyond reputewinnigt2 has a reputation beyond reputewinnigt2 has a reputation beyond repute
it is turbo surging...your turbos are near the surge point....
symptoms are only in high gears and realtiv high boost at low rpm...
over 3000rpm in most cases it goes away..
i am shure you have 1 bar wastegates
Old May 12, 2014 | 12:35 AM
TabooPc's Avatar
Originally Posted by winnigt2
it is turbo surging...your turbos are near the surge point.... symptoms are only in high gears and realtiv high boost at low rpm... over 3000rpm in most cases it goes away.. i am shure you have 1 bar wastegates
I have my actuators cracking at 1bar currently.
Is there a good way to cure this, or is this just a characteristic of turbos that spool very fast?
Old May 12, 2014 | 05:25 AM
MadWhip's Avatar
MadWhip has a reputation beyond reputeMadWhip has a reputation beyond reputeMadWhip has a reputation beyond reputeMadWhip has a reputation beyond reputeMadWhip has a reputation beyond reputeMadWhip has a reputation beyond reputeMadWhip has a reputation beyond reputeMadWhip has a reputation beyond reputeMadWhip has a reputation beyond reputeMadWhip has a reputation beyond reputeMadWhip has a reputation beyond repute
Tune?
Old May 12, 2014 | 01:44 PM
TabooPc's Avatar
Originally Posted by MadWhip
Tune?
Protomotive tune
White991TT
Mar 8, 2016 06:01 AM
sdg1871
Nov 22, 2015 07:27 PM
flewis763
Oct 4, 2015 04:14 PM
